BT Speedtest can't run?
- BT Speedtest can't run?
11-04-2010 8:19 PM
Maybe Plusnet might know when they get in tomorrow morning? Because it does say if this problem persists raise the issue with your service provider, and I'd think what with it not being to run all day it would come under the heading "persistent problem".
Re: BT Speedtest can't run?
11-04-2010 8:22 PM
11-04-2010 8:26 PM
EDIT: Just tried that link and got same message? Does it run for you Jim?
11-04-2010 8:30 PM
At which stage did it fail
11-04-2010 8:51 PM
11-04-2010 9:41 PM
12-04-2010 3:14 AM
Download speed achieved during the test was - 871Kbps
Acceptable range of speeds is 400-2000 Kbps.
DSL Connection Rate :1504 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
Assured Rate IP Profile for your line is - 1250Kbps
using your link http://217.35.209.142/ I get:
Download speed achieved during the test was - 867Kbps
Acceptable range of speeds is 400-1250 Kbps.
no mention of dsl connection rate.
I am now very puzzled!
Any Mods / PN staff care to comment? I have raised the issue in the past, I think with Matt Taylor / Bob Pullen!
12-04-2010 8:53 AM
Same error as described above, on both links.
Was working fine a few days dack.
12-04-2010 8:57 AM
12-04-2010 11:44 AM
12 Apr 2010 @ 03:07 (Belkin G Router) http://217.35.209.142/
PN IP Profile 1250Kbps
12 Apr 2010 @ 11:37 (Belkin G Router) http://www.speedtester.bt.com/
Download speed achieved during the test was - 862 Kbps
IP Profile for your line is - 1250 Kbps
12-04-2010 12:29 PM
