BT Home Hub 5
- Re: BT Home Hub 5
Re: BT Home Hub 5
23-01-2014 3:27 PM
Before on Netgear DGND3700v2:
Sync: 18539K / 1279K
SNR: 3.0 / 7.5
Line Attenuation: 30.5 / 16.9
BT IP: 16.36 Mb
PN IP: 16.3 Mb
Now on BT Home Hub 5:
Sync: 17322K / 1155K
SNR: Unknown
Line Attenuation: Unknown
BT IP: 15.28 Mb
PN IP: 16.3 Mb (at the moment will reduced to 15.2 soon)
So, overall BT Home Hub 5 is pretty ok but a let down of 1 Meg loss and no information of full line stats! But, it should be ok for FTTC as I expecting this FTTC will be full sync rate (if not revert back to Netgear DGND3700v2 via BT Openreach Modem)
Wifi on 2.4GHz is still strong overall, but it connected speed at 150.0Mbps (I suppose this is ok for FTTC to get 80Mbps in wifi) Haven't try 5.0GHz yet as my device isn't support this at present.
1. Product name: BT Home Hub
2. Serial number: **************************
3. Firmware version: Software version 4.7.5.1.83.8.173.1.4 (Type A) Last updated Unknown
4. Board version: BT Hub 5A
5. ADSL uptime: 0 days, 01:01:09
6. Bandwidth: 1155 / 17322
Re: BT Home Hub 5
23-01-2014 4:16 PM
@Perdrix
Was your Hub a new one or second hand? If you look through this thread there is a post to a link with simple instructions to follow They are for Home Hub 3 I think but it worked for my Home Hub 5). You just need to put in your Plusnet user name (name@plusdsl.net) and password in the two lines in the settings tab where the BT details are (overwriting them)
Re: BT Home Hub 5
23-01-2014 5:47 PM
Now on Netgear DGND3700v2:
Sync: 18311K / 1279K
SNR: 3.0 / 6.7
Line Attenuation: 30.5 / 16.8
BT IP: 16.16 Mb
PN IP: 16.1 Mb
Re: BT Home Hub 5
23-01-2014 6:13 PM
I bought it off gumtree for £25, but it had clearly never been used. I may have had finger trouble before as I tried again a bit ago and it accepted my xxx@plusdsl.net username this time. So it may be that it knows that plusnet is part of BT! It most certainly wouldn't accept my xxx@extreme5.pipex.net (was Pipex, then Opal, now TalkTalk) username at all.
I'll know if it all works on Plusnet on 3rd February as that is when the Openreach engineer is coming to transfer my telephone line from the POTS/ADSL connection in the cabinet to the VDSL2 DSLAM and the service is transferred away from TalkTalk (hurrah)!
Now if only someone knows how to fully unlock this baby ...
Dave
Re: BT Home Hub 5
23-01-2014 6:18 PM
Re: BT Home Hub 5
23-01-2014 7:10 PM
before connecting it I left internet off for about 45 minutes
2 days after installing HH5 the firmware updated to
BT Home Hub 5 (Type A) | Software version 4.7.5.1.83.8.173.1.6 | Last updated 10/01/14
also bought the bt dongle for my laptop so i could use ac great around here as no one else on the 5 ghz.
the only annoying thing so far is not being able to change the dns on it
Re: BT Home Hub 5
23-01-2014 7:50 PM
Quote from: goldenadsl And even worse that BT Home Hub 5 had high ping, and impossible to use thinkbroadband broadband quality monitor respond to ICMP pings
Am intreagued by this, as I get pings down at the 10ms mark on my Fibre line, which is no worse than my previous homebuilt router + openreach modem.
Are you sure you always get high pings with it? I find quite often I will randomly get connected to a gateway endpoint which gives me noticeably worse pings than the others.
Like this ping graph below (look at 3-4ms jump on the second disconnection):
Re: BT Home Hub 5
23-01-2014 7:54 PM
Good to see you got yours working Dave
Re: BT Home Hub 5
23-01-2014 8:00 PM
On thinkbroadband forum MrSaffron say there is no respond to ICMP ping support on BT Home Hub 3, 4 and 5. See here: http://www.thinkbroadband.com/ping/guides/routers.html
Jimbof how did you managed to get broadband qualty monitor work on the home hub 5? What setting did u use?
Re: BT Home Hub 5
23-01-2014 8:09 PM
Re: BT Home Hub 5
23-01-2014 8:14 PM
Re: BT Home Hub 5
23-01-2014 8:39 PM
5. VDSL uptime: 0 days, 03:23:25
6. Data rate: 20000 / 79995
7. Maximum data rate: 30093 / 96660
8. Noise margin: 12.6 / 10.3
9. Line attenuation: 0.0 / 9.5
10. Signal attenuation: 0.0 / 9.5
I guess it is possible they only populate it on VDSL. I know HH4 doesn't have any line stats either of significance for ADSL, but HH3 does have some. You can get the stats from immediately after a connection on HH4 by looking in the Event Log (filter for WAN). I wonder if that also works for HH5 in ADSL mode?
Re: BT Home Hub 5
23-01-2014 11:27 PM
On 23 January 2014 16:08, <richard****************@openreach.co.uk> wrote:
Hi *************,
The very good news is your cabinet completed all engineering activities yesterday and has now gone forward to be commissioned ready for service.
It normally takes 10 days to be ready to place orders.
So you should be able to place an order for Fast Broadband by mid-February with your service provider.
All the post code checker sites should be updated as the cabinet progresses through to RFS.
Regards
Richard **************************
Openreach NGA
So, does BT Home Hub 5 automatically change from ADSL2+ to VDSL itself on it own when BT Engineer activated FTTC at the cabinet?
Re: BT Home Hub 5
24-01-2014 9:24 AM
It also directly contradicts what she allegedly wrote to you a couple of days ago when she, the CEO of the infrastructure division of an FTSE 100 company, personally closed your support case.
The grammar and spelling are way better than the modern and medieval languages graduate from Cambridge could manage too.
Curiouser and Curiouser in the words of Alice.
Re: BT Home Hub 5
24-01-2014 2:47 PM
Quote from: goldenadsl My VDSL FTTC will be ready to order from service provider say openreach NGA as it say on my email:
The HH5 auto-detects the WAN connection type, so if you are with Plusnet at the moment the most you would have to do is reboot the router I believe (as username / password shouldn't change).
However, Plusnet don't do self-install (yet) I believe so Openreach or a contractor will still want to come out and install a modem for you, and they need to get into the cabinet too to hook your line up to the FTTC equipment, after having disconnected it first from the ADSL at the exchange.
