At wits end....download to take hours and HOURS!
- Re: At wits end....download to take hours and HOUR...
- « Previous
- 1
- 2
- Next »
Re: At wits end....download to take hours and HOURS!
29-01-2016 11:32 PM
If you used your actual phone number then The exchange data shows that you cant get CN21 adsl2+ .
If the noise on the line is due to an external source then it may not have been present when the engineer was there.
The timing of the drop in speeds for you and Winaria do not seem to be the same. Whilst the drop in speed is still there
you may each have different faults.
You havent said which cabinet you are on - if you dont want to broadcast that, perhaps PM Winaria and see if he is on the same one.
I will read through the thread tomorrow and see if I have missed anything obvious.
Message 16 of 24
(1,088 Views)
30-01-2016 12:48 PM
Yes used phone number. We are on different cabinets.
Message 17 of 24
(1,088 Views)
30-01-2016 2:12 PM
As the speed loss is so erratic could it be relative to what you are doing. You mention dropbox and I have been reading this
http://community.plus.net/forum/index.php/topic,148159.0.html ; on the fibre forum where it appears some sites are being run
through an IWF filter. You could also try the test download on thinkbroadband tools. When I have had a problem I just set it going and see
how long it says it will take. It gives a list of what approx times equates to speed.
Message 18 of 24
(1,088 Views)
30-01-2016 3:08 PM
As said before though it is also taking ages to download on my sky on demand, and browsing and loading of pages is also slow.
Message 19 of 24
(1,088 Views)
30-01-2016 3:18 PM
Did a test on www.kitz.co.uk ; - what does the "check" section below mean?
RAG Test Results
Fixed: 1Mbps and 2Mbps available
radsl: 512Kbps and 256Kbps available
MAX: ADSL Max is available
TPON: TPON/Fibre not recorded
Check: The check identified another service on your line which may prevent you from ordering a new ADSL connection. Examples are : Existing adsl connection, DACs, LLU, TPON etc
RAG Test Results
Message 20 of 24
(1,088 Views)
30-01-2016 3:26 PM
Just done a test download 3.32, up 0.31, ping 54.63
Message 21 of 24
(1,088 Views)
30-01-2016 6:22 PM
Quote from: jdmac Did a test on www.kitz.co.uk ; - what does the "check" section below mean?
I dont know but I suspect kitz imports a Broadband checker from (possibly) BT
all it is saying that it knows there is already have a broadband connection (ie Plusnet)
So that might/ prevent you from ordering a new connection. I believe such information can be useful
when moving house - Maybe someone leaving at short notice didnt cancel or move the BB. or the service
move has been delayed. So it is really just a check.
Message 22 of 24
(1,088 Views)
30-01-2016 11:12 PM
Quote from: cedlor I dont know but I suspect kitz imports a Broadband checker from (possibly) BT
Scroll down to the very bottom of the results page!
Message 23 of 24
(1,088 Views)
31-01-2016 10:47 AM
Quote from: spoon
Thanks - now cedlor knows
Message 24 of 24
(1,088 Views)
- « Previous
- 1
- 2
- Next »
