Imgur.com is unusable on Plusnet.
Azagoth
The site simply will not open when using my Plusnet connection, if it doesn't time out it just sits there not loading.  It works fine on my neighbour's Virgin line, works fine on my mate's SKY line and it works fine from my phone over 4G but it will not load over my Plusnet connection. It works via the Hola VPN plug-in though, so that would suggest that it's something to do with Plusnet's network.
Why is this?
Is anyone else experiencing this?  It's making browsing Reddit and other sites that link their images from Imgur impossible.
1 REPLY
Fixes: 154
Re: Imgur.com is unusable on Plusnet.
mod:note
locked in favour of https://community.plus.net/forum/index.php/topic,148159.0/topicseen.html
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
