Asus N66U Users Thread
- Asus N66U Users Thread
Re: Asus N66U Users Thread
23-03-2013 9:32 AM
Quote from: darklight Seems not able to pick up the 5ghz wifi on the laptop or iphone 4, i tagged the 5ghz SSID as plusnet_5g, not picking nothing up, other than the 2.4ghz wifi which is very strong.
You won't pick up 5 on your iPhone as it dosnt support it,and probably the same on your laptop then you will need to install a new wifi card and a third antenna which I have just done. I have a intel centrino 6300 ultimate n card installed. Card was £20 antenna was £2 easy on my toshiba laptop to fit.
23-03-2013 9:40 AM
23-03-2013 9:55 AM
23-03-2013 11:26 AM
To be honest, I've got both my SSIDs labelled the same. I've read multiple different articles about the good and bad points for doing this, and the same for having separately identified SSIDs. Maybe I'm just very lucky, but all of my 5GHz capable devices went straight onto that range, while everything else connected via the 2.4GHz signal. Lovely.
23-03-2013 12:33 PM
Yes I did the same when I bought the Apple Airport Extreme a year back, ie set 2.4 & 5 with the same SSID. The only drawback (if you could call it a drawback) is that you don't know which one your laptop/phone has connected to. As I set the frequency on my android phones to auto, in theory it could connect to either, so it needs to be queried to figure out which one it is connected to. So I just appended a 5 to the SSID of 5ghz signal. Done the same with the Asus rt-n66u, which is located on the second floor near the master socket. Gives brilliant signal throughout the house.
the 352 Beta is out, one of the sites is this. I'll wait for the official release, and I guess Merlin will also probably update their firmware, after the official release.
23-03-2013 12:35 PM
pings are a nightmare on 5ghz wireless
23-03-2013 12:39 PM
23-03-2013 12:49 PM
23-03-2013 12:56 PM
jim:quote
24-03-2013 9:57 AM
I've done a 30-30-30 reset to clear out the NVRAM, still it locks me out, and I can't get to the router GUI. I also followed the Merlin advice here to erase the nvram settings that tell the router that someone is already logged in, since the router doesn't allow more than one simultaneous user to be logged in. Still no go.
Any ideas would be appreciated, before I pack it up and get a replacement
24-03-2013 10:21 AM
Is it just the router GUI that you are locked out of, or the whole network and internet access?
Are you connecting via ethernet or wifi? Is it the same on both?
24-03-2013 10:29 AM
It's just the router GUI. The network works perfectly, both the 2.4 & 5 work flawlessly.
Yes I have tried connecting to the router via both by wifi, and ethernet by connecting to one of the router's ethernet port. What RMerlin says in this thread could be the cause, but then I use just one laptop with the same IP address to connect to the router, so why and how would it apply here, I am still wondering.
24-03-2013 10:38 AM
Are you using the same web browser on your laptop each time?
24-03-2013 10:43 AM
Just remember to 'log out' when you've finished making your changes to avoid the issue.
24-03-2013 10:47 AM
Quote So you are getting the "You cannot Login unless logout another user first" message?
No I do not get any such message. The browser just does not do any thing. I've left the browser for 10 minutes, the progress bar barely moves. I've used different browsers from different laptops windows/mac, my mobile etc, nothing doing. Puzzling.
