Anyone on Plus Using Limewire Successfully?
trevor2522
I can't even establish a connection with Limewire.  I have tried setting the port numbers recommended on my BT Voyager 210 but nothing works.
If you managed to connect, please tell me how!  Thanks.
2 REPLIES 2
VileReynard
Fixes: 20
Re: Anyone on Plus Using Limewire Successfully?
Check your PlusNet firewall settings - there's an option to block common P2P port settings.
bobpullen
Fixes: 316
Also, what package are you on?
