So slow!
- So slow!
So slow!
19-12-2007 7:45 PM
I know I am on the Ardwick exchange in Manchester which is heavily contended, but I am getting less than 1MB connection speed.
Is there anything I or Plus Net can do to improve this?
Re: So slow!
19-12-2007 8:14 PM
Heres my speed test...
19-12-2007 20:12:24 153.5
19-12-2007 16:00:18 839.5
19-12-2007 15:59:46 692
17-12-2007 20:31:46 1377.2
13-12-2007 11:08:09 1377.7
C'mon PN thought we had passed this bit!!
Re: So slow!
19-12-2007 9:50 PM
Its never been this bad. Usually nearer 5.5M.
Is it something to do with Santa? (Wrexham)
Re: So slow!
19-12-2007 11:25 PM
Re: So slow!
20-12-2007 12:17 AM
Quote from: PJ -snip
I did that and my profile is 3000 and getting 100kB/s, should be 250-300, but in a real download test I'm getting 30kB/s at best
Re: So slow!
20-12-2007 7:49 AM
Re: So slow!
20-12-2007 9:08 AM
There weren't any speed related issues that I was aware of last night.
If the problem continues, please let me know and I'll run some tests.
Re: So slow!
21-12-2007 8:27 PM
Apparently Christmas Lights are a bad source of interference.
Have a look at: http://www.dougrice.plus.com/Erlangs/adsl.htm
Many people have reported it useful. A collegue at work said he told his team and 9 out of the 10 people who read my page who tried it got a dramatic increase in speed.
This is what BT's Suppliers Information note SIN 346 states ( http://www.sinet.bt.com/346v2p6.pdf )
"7.3 Additional notes about CPE filters.
Note that the standard BT PSTN CPR interface is a 3 wire circuit whereby the bell wire is AC-coupled from the line B.
This bell wire must either be filtered by the filter or left open circuit at the Line Port and recreated at the Telephony Port of the filter. This is may be acheived using a 1.8uf capacitor between line B ( pin5) and the bell wire ( pin4) at the Telephony Port."
Merry Christmas
Doug
Re: So slow!
24-12-2007 10:03 AM
The speed test has completed on test server speedtester1.nat.bt.com for user xxxxxxxxxxx and you have downloaded a 1.7Mb file at a speed of
178 kilo bits per second (Kbps), your service bandwidth will have been quoted to you in kilo bits per second.
Your IP address is 84.92.166.67, your browser is reported as being Mozilla 5.0 and is running on Macintosh Intel Mac OS X.
BT would regard the speed ranges shown below as normal service:
For 250kbps End Users speeds between 50 - 250kbps.
For 500kbps End Users speeds between 100 - 500kbps.
For 1000kbps End Users speeds between 200 - 1000kbps.
For 2000kbps End Users speeds between 400 - 2000kbps.
[Moderator's note by Peter (PJ): Removed telephone number for privacy reasons]
Re: So slow!
24-12-2007 2:59 PM
ADSL Line Status
Line State: SHOWTIME
Modulation: G.dmt
Startup Attempts: 1
Max Tx Power: -38 dBm/Hz
DSLAM Vendor: TEXAS_INSTRUMENTS
Elaspsed Time: 0 days 22 hours 54 minutes 51 seconds
Downstream
Upstream
SNR Margin 28.2 30.0 dB
Line Attenuation 33.1 17.0 dB
Errored Seconds 3 0
Loss of Signal 0 0
Loss of Frame 0 0
CRC Errors 4 0
Data Rate 2272 288 kbps
Latency FAST FAST
Re: So slow!
24-12-2007 4:58 PM
Unless there is some reason for staying on the fixed speed service I suggest you raise a ticket requesting your service be upgraded to maxADSL.
Note that the sync speed is the rate at which ATM packets are transmitted. Allowing for ATM and TCP/IP overheads, and data management effects means actual throughput rates will be much less than that.
Re: So slow!
24-12-2007 5:08 PM
Given that you are on a fixed rate product and your speed is that low it is classed as a fault.
Going to max may help a bit as you will have a higher base speed from which BT throttle you but the fact that your exchange has been red since November and we have passed the fix date nothing much is likely to improve until sometime in January
