Anyone on Plus Using Limewire Successfully?
- Anyone on Plus Using Limewire Successfully?
24-12-2007 2:03 PM
I can't even establish a connection with Limewire. I have tried setting the port numbers recommended on my BT Voyager 210 but nothing works.
If you managed to connect, please tell me how! Thanks.
Message 1 of 3
(1,773 Views)
2 REPLIES 2
Re: Anyone on Plus Using Limewire Successfully?
24-12-2007 2:18 PM
Check your PlusNet firewall settings - there's an option to block common P2P port settings.
Message 2 of 3
(319 Views)
24-12-2007 2:50 PM
Also, what package are you on?
Message 3 of 3
(319 Views)
