Anyone else seeing a reduction in downstream through put tonight ?
- Re: Anyone else seeing a reduction in downstream t...
18-12-2013 8:00 PM
As the tile suggests, my throughput was fine nearly maxing using utorrent at around 18:30 , but speedtests are showing 55-60mbps and not the usual 70+mbps except for the btwholesale speedtester which gives a normal 74mbps result , I'm currently on PTW-AG03 and the status checker isn't reporting it to have more customers connected than other gateways so why the slow down ,?
Update: as of 10pm throughput back to normal more or less
Message 1 of 3
(529 Views)
2 REPLIES 2
Re: Anyone else seeing a reduction in downstream through put tonight ?
19-12-2013 9:04 AM
Message 2 of 3
(283 Views)
19-12-2013 2:46 PM
If it starts to be a regular occurrence if i tried the Pro Add on if it would make any difference, I know it shouldn't do, but it did for someone else who is on unlimited fibre?
http://forums.thinkbroadband.com/plusnet/t/4287026-pro-add-on-to-unlimited.html If there was a choice of not having traffic management i would choose that every time,
Message 3 of 3
(283 Views)
