Any StumbleUpon users?
- Re: Any StumbleUpon users?
16-03-2008 11:49 PM
Are there any StumbleUpon users amongst us? I've been having problems with the Firefox plugin since volunteering for a trial we're running and I'm wanting to find out if people who aren't part of this trial are experiencing similar symptoms. Take a look here for the background.
Would appreciate somebody trying to replicate the problem so I can narrow it down to the trial as opposed to PlusNet connections in general.
16-03-2008 11:59 PM
You need to move the link as it is to the hidden forums.
error is
Quote An Error Has Occurred!
The topic or board you are looking for appears to be either missing or off limits to you.
17-03-2008 12:02 AM
17-03-2008 12:04 AM
Quote Does anybody use the StumbleUpon Firefox plugin?
I have a very peculiar problem and I want to rule out Aladdin as a potential cause before I investigate further. I've just been stumbling images and found that almost everytime I clicked the Stumble button I got a connection reset error in Firefox. If I refresh the page though the website displays OK.
Disconnected and tried RIN and it worked seamlessly. Now back on PlusNet and the problem persists. Can somebody whose also on Aladdin give this a whirl and let me know their findings?
Basically, I just need confirmation that there are people able to use StumbleUpon without experiencing the above problem.
17-03-2008 12:28 AM
17-03-2008 12:32 AM
17-03-2008 6:51 AM
No problems here either Bob.
17-03-2008 7:52 AM
Scott
17-03-2008 8:34 AM
17-03-2008 3:44 PM
Quote from: mcgurka Not sure if this is related or not, but I am being plagued by 'connection was reset' errors when trying to access bebo, myspace etc... but only on a PN connection?
It's the same error but for those not on the trial the cause must be different.
David
