Broadband Cutoff?
- Broadband Cutoff?
Broadband Cutoff?
17-03-2008 9:50 AM
Hi Guys, woke up this morning, went to check my mail, nothing, strange i thought. Tried accessing Web, Hmm http://212.159.5.18/Failed_Billing.html ; Err any reason why i have been cut off, im paid up untill 24th and have a direct debit set up.
Message 1 of 9
(1,643 Views)
8 REPLIES 8
Re: Broadband Cutoff?
17-03-2008 9:57 AM
Anythign to do with me being 4.5 gig over my limit? I am set to go over and pay the fee's so no reason there if thats whats happened.
Message 2 of 9
(684 Views)
17-03-2008 10:23 AM
Ah. It's not due to you being over your limit, but a data transfer watch that you have set.
If you change this within the portal and then restart your router, your downloading should continue as per normal.
Message 3 of 9
(684 Views)
17-03-2008 10:26 AM
Dohh! I am at work and need access. Cannot restart my router from here.
Message 4 of 9
(684 Views)
17-03-2008 10:41 AM
I'll give it a kick from here.
Hopefully it should automatically reconnect.
Message 5 of 9
(684 Views)
17-03-2008 10:45 AM
Thank you. Very Much.
Message 6 of 9
(684 Views)
17-03-2008 10:55 AM
Ok, I've done an "intrusive one shot check" which should take your connection off and then hopefully, your router should reconnect!
Message 7 of 9
(684 Views)
17-03-2008 3:29 PM
Cor....the things you guys can do!
James - I think I left my bathroom light on this morning - could you do me an "intrusive one shot illumination disablement"?
Message 8 of 9
(684 Views)
17-03-2008 3:32 PM
No.
Speak to your electrician.
Message 9 of 9
(684 Views)
