Another season change, another speed drop
- Re: Another season change, another speed drop
- « Previous
- 1
- 2
- Next »
08-10-2014 12:20 PM
Fault is already raised
Using the engineer socket made no real difference, disconnects still happened & I'm afraid it cant be left out any longer. So back on the filtered faceplate now
Also I notice my uplaod is back to 440 atm, I do hope that wont be permanent
Message 16 of 17
(164 Views)
08-10-2014 1:07 PM
Hi KitFox,
Thanks for raising the fault ticket, it is currently with the correct team and I would expect you to receive an update within the next 24 hours.
Message 17 of 17
(164 Views)
- « Previous
- 1
- 2
- Next »
