After activation low speed
Ichief
Hi yesterday I got message and email that my broadband is ready to go. I plugged router everything cables okay. I got blue light on router. This morning when I checked internet is speed is very low, just 0.26 kb/s. What can be the problem? Thank you
26 REPLIES 26
Fixes: 382
Re: After activation low speed
@Ichief Difficult to say, but one idea - reboot the Hub and see if it makes a difference - if not come back and we can take a deeper look.
Ichief
I did still same
Fixes: 382
OK. This may be overkill, but it will give us some data to make an educated assessment.
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (Ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS', and sight of the broadband connection status from your Hub (with the 'Username' obscured) would be a good starting point.
For the Hub One -
For the Hub Two -
Ichief
@jab1 I’m on the mobile phone I took ss from 1st website that you send me but I couldn’t post in this topic . 2nd test website I couldn’t open it because of very low speed
Fixes: 382
Do you have a desktop/laptop - mobiles/tablets default  to a stripped-down 'mobile-friendly' interface which is not problem-solving 'friendly', although you can request the 'desktop' site.
Ichief
Fixes: 382
Was that last post using your land line phone number, or merely address - there is missing information?
Ichief
Moderator's note by Mike (Mav): Personal information redacted from a public forum.
Ichief
It’s my landline phone number
Fixes: 382
That wasn't what I was asking for - somewhere towards the bottom of that page, there should be a section headed 'max observed speeds'.
Ichief
These are bottom of the page
Ichief
I couldn’t find max observed speed. Sorry
Fixes: 382
OK - in that case I suspect there is an issue with your connection. I would ring in and report the problem, because it appears even the BT/OpenReach  test equipment can't see your line.
Ichief
Please
