Advice please about sync speed
- Re: Advice please about sync speed
10-12-2011 3:57 PM
Hi, I had interleaving switched off not so long ago and all has been well until we have had several power outages in the last few weeks, the cause was a pole across the road to us which eventually fell down. Its now been fixed but my speed has dropped, I've checked on the BT site and the results are as follows
FAQ
Results Image not loaded
Test1 comprises of Best Effort Test: -provides background information.
Download Speed
5838 Kbps
0 Kbps 7150 Kbps
Max Achievable Speed
Download speed achieved during the test was - 5838 Kbps
Additional Information:
Your DSL Connection Rate :8128 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 6500 Kbps
My router is syncing at 8128 but on the Plusnet my account area it states profile 6.5 mb which has dropped, do I need to raise a ticket or will it rectify itself ? my router readings are
Uptime: 0 days, 3:20:49
DSL Type: G.992.1 annex A
Channel mode: Fast
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,264 / 8,128
Bandwidth (Up/Down) [kbps/kbps]: 448 / 8,128
Data Transferred (Sent/Received) [kB/MB]: 0.00 / 71.37
Output Power (Up/Down) [dBm]: 12.0 / 8.0
Line Attenuation (Up/Down) [dB]: 0.0 / 4.0
SN Margin (Up/Down) [dB]: 30.0 / 8.0
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 7
HEC Errors (Up/Down): 0 / 5
regards
jono
FAQ
Download Speed
5838 Kbps
0 Kbps 7150 Kbps
Channel mode: Fast
regards
jono
Message 1 of 5
(883 Views)
4 REPLIES 4
10-12-2011 4:26 PM
You will need to wait for the BT profile to pick up to 7150kbps - it could take 3 days
Message 2 of 5
(423 Views)
10-12-2011 5:23 PM
Thanks Jim, Was not quite sure if I needed to raise a ticket, I have the router on constantly but with the electric keep going off it messed things up.
regards and thanks for the quick reply
Jono
Jono
Message 3 of 5
(423 Views)
12-12-2011 3:55 PM
Hi Jono,
I've upped your profile on our side to 7150, hopefully it'll make a difference for you.
Message 4 of 5
(423 Views)
12-12-2011 6:43 PM
Hi Thanks Matt, Just received letter today and they are going to knock electricity off on Saturday for 6 hrs to do some work at the station down the road, Electricity off and on like a beacon. Thanks again.
regards
jono
regards
jono
Message 5 of 5
(423 Views)
