Very High Ping! 2 Days in a row
- Very High Ping! 2 Days in a row
12-12-2011 8:10 PM
I online game alot and twice when i've come home its been unplayable because of terribly highping. Download seems to be ok, Abit lower than what I usually get , done a few tracerts for you to see. Hope you can help! From speed test it seems to spike cause every1 test i do I get 38 ms then 150-300. Thanks for any Help
Tracing route to plus.net [212.159.8.2]
over a maximum of 30 hops:
1 67 ms 99 ms 99 ms dsldevice.lan [192.168.1.254]
2 300 ms 278 ms 255 ms lo0-central3.pcl-ag05.plus.net [195.166.130.36]
3 273 ms 266 ms 274 ms gi7-5-531.pcl-gw01.plus.net [84.93.254.65]
4 275 ms 277 ms 247 ms po5.ptn-gw01.plus.net [212.159.1.131]
5 241 ms 212 ms 202 ms gi3-0.pih-cr1.plus.net [212.159.1.177]
6 204 ms 218 ms 210 ms if25.pih-lb04.plus.net [212.159.0.18]
7 221 ms 209 ms 247 ms portal.plus.net [212.159.8.2]
Trace complete.
Pinging plus.net [212.159.8.2] with 32 bytes of data:
Reply from 212.159.8.2: bytes=32 time=559ms TTL=250
Reply from 212.159.8.2: bytes=32 time=546ms TTL=250
Reply from 212.159.8.2: bytes=32 time=556ms TTL=250
Reply from 212.159.8.2: bytes=32 time=594ms TTL=250
Ping statistics for 212.159.8.2:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 546ms, Maximum = 594ms, Average = 563ms
EDIT : Currently no videos/stream buffering at normal rate, whats up >.>
Trace complete.
Message 1 of 3
(749 Views)
2 REPLIES 2
Re: Very High Ping! 2 Days in a row
12-12-2011 9:16 PM
So I've just checked my usage, its coming really close to the available amount, the new month start tomorrow, could it be plusnet have reduced it till tomorrow?
Message 2 of 3
(353 Views)
12-12-2011 9:28 PM
Depending on your package, your speed will be rate limited.
However, you should have received a warning email that you were close to your limit.
You may find the link below useful:-
http://www.plus.net/support/broadband/products/res_broadband_faq.shtml#monthlyAllowance
Professionals are predictable - it's the amateurs that are dangerous!
Message 3 of 3
(353 Views)
