ASUS RT-N66U N900
- Re: ASUS RT-N66U N900
- « Previous
- Next »
12-02-2013 11:14 PM
Got it from dabs for £106 + £1.99 postage I couldn't seem to get it any cheaper they have got about 30 in stock from today.ebuyer is £115 and scan is £113
Message 31 of 38
(428 Views)
15-02-2013 7:33 PM
Received the asus today what a nice looking router. How does everyone with the asus on here have there router flat,on the stand, hanging on the wall
Message 32 of 38
(428 Views)
15-02-2013 7:40 PM
Got mine flat - not sure which is the ideal way of mounting. Wireless seems good everywhere.
I would check out the http://forums.smallnetbuilder.com/forumdisplay.php?f=40 forums as it has the custom firmwares (merlin/tomato) which run better.
Message 33 of 38
(428 Views)
15-02-2013 10:37 PM
Flat here, but I'm sure it's happy whichever way you want it! Remember the two outer antennae are supposed to be angled at 45 degrees (outwards) and the middle one straight up. In theory it's supposed to give better wifi performance like that, although I haven't needed to test that theory.
Message 34 of 38
(428 Views)
15-02-2013 11:16 PM
Ok I'll try it flat, I know with the routers I got at mo they perform better upright.
I wish the 26th would hurry upppppppppp
Message 35 of 38
(428 Views)
22-02-2013 5:55 PM
Just out of interest do you have to use the bt modem with the asus or could you use the asus on its own. I'm guessing you have to use both
Message 36 of 38
(428 Views)
22-02-2013 6:05 PM
Both. No modem built into this particular Asus router.
Message 37 of 38
(428 Views)
22-02-2013 6:15 PM
Okey dokey no probs
Message 38 of 38
(428 Views)
- « Previous
- Next »
