Which wireless card?
- Which wireless card?
21-02-2013 11:19 PM
I am currently using the built in wireless card which came with the desktop but only get half the speed and consistent signal. I am using a Dell Vostro and the wireless network card is broadcom 802.11g in device manager.
Would a new wireless card help with the connection and speeds and if so which one do I get? I'm no expert with these sorts of things but guess I would need wireless n??? Don't want to spend too much if possible but want to connect as reliably and fast as possible to the plusnet unlimited. I can get speeds of 17mbps on ipad and notebook but barely getting 5mbps on desktop
Message 1 of 7
(1,155 Views)
6 REPLIES 6
Re: Which wireless card?
22-02-2013 9:51 AM
A new usb 'n' wifi card would probably help, they can be had for a few £'s on ebay.
Message 2 of 7
(720 Views)
22-02-2013 10:07 AM
Yes it would help do you know if its a mini pic-e card in it, or what is the exact vostro model reason I ask is I have a spare atheros n card
Message 3 of 7
(720 Views)
22-02-2013 10:35 AM
One thing that is often overlooked is obstruction of reception by the case.
Does the aerial have clear line-of-sight to the wireless base?
I try to buy internal cards that have aerials on a lead so that they can be positioned clear of obstructions.
If none of that applies and a USB "n" device is what you're after my personal favourite at present is the EdiMax EW-7711UAN.
This is quite small and comes with a short semi-rigid extension lead (not generally shown in sales information) allowing a degree of repositioning.
Note that there are several variants with similar names, here is that exact one from a typical eBay seller: http://www.ebay.co.uk/itm/330797034041?
Message 4 of 7
(720 Views)
22-02-2013 4:26 PM
Quote from: thomasjc1 Yes it would help do you know if its a mini pic-e card in it, or what is the exact vostro model reason I ask is I have a spare atheros n card
Its a Dell Vostro 400 desktop. I haven't opened it up yet so not sure if I need a mini card or standard
Message 5 of 7
(720 Views)
22-02-2013 4:31 PM
Should have a selection of PCI and PCIe slots so it will depend which are used/free at present.
Message 6 of 7
(720 Views)
22-02-2013 4:36 PM
well if its any use its a atheros ar5b93 half size pci-e card
Message 7 of 7
(720 Views)
