ADSL2 or ADSL2+
- Re: ADSL2 or ADSL2+
Re: ADSL2 or ADSL2+
19-12-2012 5:18 PM
Re: ADSL2 or ADSL2+
19-12-2012 5:22 PM
Oh well, we may move sometime next year so will let SWMBO know what areas we can go to
Forum Moderator and Customer
Re: ADSL2 or ADSL2+
19-12-2012 6:36 PM
You should be getting more than that even on ADSL, never mind ADSL2+.
If you unplug the filter from the test socket, and plug a (preferably corded) phone into the test socket, what do you hear after dialling 17070 option 2?
Re: ADSL2 or ADSL2+
19-12-2012 8:04 PM
Re: ADSL2 or ADSL2+
20-12-2012 12:47 PM
Quote from: Estragon If you unplug the filter from the test socket, and plug a (preferably corded) phone into the test socket, what do you hear after dialling 17070 option 2?
Line appears to be quiet - couldn't hear any noise at all.
Still hoping one of the DC team will pick this up shortly and offer some insight or do whatever tests may be necessary.
Re: ADSL2 or ADSL2+
20-12-2012 3:46 PM
On the off chance there I just ran a check on your phone line, and it showed a fault (Dis in exchange, I think this is the contacts somewhere). I've taken the liberty of raising this for you, hope it gets things sorted. I'll put the reference on a ticket on your account and pass it through to the phone faults team.
Re: ADSL2 or ADSL2+
20-12-2012 3:54 PM
Re: ADSL2 or ADSL2+
21-12-2012 11:19 AM
His explaination is that often the Dis fault is a false reading.
Is there anything else that can be checked/done?
Re: ADSL2 or ADSL2+
21-12-2012 12:22 PM
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image1356092432207.png"/>
All we can do really if you've eliminated everything you can wiring and hardware wise is raise another fault or push back on the phone one. Just depends which has the issue or which you'd rather pursue it through I guess.
Re: ADSL2 or ADSL2+
21-12-2012 1:34 PM
The router is always plugged directly into the test socket at the master.
It appears, from my interpretation of the graph above, that twice the internet was down for several minutes.
The only drops actioned by me recently was when I connected the Homehub a couple of days ago and then powered down later the same day to change the socket the router was plugged into.
I got a resync around 3 hours and 20 minutes ago - latest stats:
Quote Line state Connected
Connection time 0 days, 3:18:34
Downstream 5,408 Kbps
Upstream 999 Kbps
ADSL settings
VPI/VCI 0/38
Type PPPoA
Modulation ITU-T G.992.3
Latency type Interleaved
Noise margin (Down/Up) 5.9 dB / 5.3 dB
Line attenuation (Down/Up) 43.5 dB / 24.9 dB
Output power (Down/Up) 0.0 dBm / 12.9 dBm
Loss of Framing (Local) 22
Loss of Signal (Local) 2
Loss of Power (Local) 0
FEC Errors (Down/Up) 0 / 4294967248
CRC Errors (Down/Up) 36229 / 2147480000
HEC Errors (Down/Up) nil / 6
Error Seconds (Local) 9
What would you advise as to the next step.
Re: ADSL2 or ADSL2+
21-12-2012 1:57 PM
Re: ADSL2 or ADSL2+
21-12-2012 2:07 PM
Thanks Matt.
Re: ADSL2 or ADSL2+
21-12-2012 2:08 PM
Re: ADSL2 or ADSL2+
21-12-2012 2:12 PM
I'm just hoping that the intermittent dropping can be rectified and, in doing so, increase the sync.
In my village all cables are overhead including electricity supply - not sure if that has anything to do with it but maybe...
Re: ADSL2 or ADSL2+
25-12-2012 10:48 PM
The router re-synced at 6083 Down and 1024 Up and it appears it is now ADSL2+ from the stats below.
Connection time 0 days, 4:30:49
Downstream 6,083 Kbps
Upstream 1,024 Kbps
ADSL settings
VPI/VCI 0/38
Type PPPoA
Modulation ITU-T G.992.5
Noise margin (Down/Up) 2.1 dB / 5.2 dB
Line attenuation (Down/Up) 47.0 dB / 25.0 dB
Loss of Framing (Local) 55
Loss of Signal (Local) 5
FEC Errors (Down/Up) 3231023 / 0
CRC Errors (Down/Up) 36 / 2147480000
HEC Errors (Down/Up) nil / 0
Error Seconds (Local) 1
BT Speedtester is showing a profile of 5.37 so I'll have to wait for PN's to play catchup. The SNRM seems a tad low at 2.1 - was 3.5 earlier but I hope it remains stable
