Obtaining Pluse Net Gateway identity within a web server-side script
- Obtaining Pluse Net Gateway identity within a web ...
04-01-2013 1:35 PM
I want to be able to report my current PN Gateway on a page delivered by my (local) web server. I know of the Plusnet Usergroup tool 'Which Gateway' (http://usertools.plus.net/@gateway) however that runs within their web pages and all I want is the result embedded in my web page as in 'pcl-ag01'. The reason for doing this server-side is that I want to be able to see this information / web page when not at home on the PN network.
I guess I could (somehow) extract data from tracert...
Quote from: tracert
Tracing route to portal.plus.net [212.159.9.2] over a maximum of 30 hops:
1 * * * Request timed out.
2 322 ms 79 ms 55 ms lo0-central10.pcl-ag01.plus.net [195.166.128.182]
3 196 ms 38 ms 36 ms link11-central10.pcl-gw01.plus.net [84.93.249.20]
4 196 ms 61 ms 36 ms xe-0-2-0.pcl-cr01.plus.net [212.159.1.0]
5 209 ms 36 ms 36 ms po2.pcl-gw01.plus.net [195.166.129.41]
6 266 ms 44 ms 44 ms gi5-8.ptp-cr01.plus.net [84.93.224.48]
7 245 ms 45 ms 45 ms vlan2658.ptp-elb02.plus.net [84.93.224.45]
8 205 ms 46 ms 45 ms portal.plus.net [212.159.9.2]
Trace complete.
If the AP / modem supported TelNet I might beable to extract the data from there, however they do not support TelNet. Would be ral nice ifthere were a PN cgi script which delivered just the gateway name for a given IP address or account name - e.g. http://plus.com/cgi/gateway.cgi?user=townman returns just the Gateway ID.
All seems a bit tedious - anyone got a workable suggestion please?
Cheers,
kevin
Re: Obtaining Pluse Net Gateway identity within a web server-side script
04-01-2013 1:55 PM
$gateway_o = exec("netstat -rn -f inet | grep default");
$gateway = preg_split("/\s+/",$gateway_o);
$gateway_ip = $gateway[1];
$gateway_host = gethostbyaddr($gateway_ip);
$gateway_host_parts = explode(".",$gateway_host);
$gateway_id = $gateway_host_parts[1];
Although you have to run that on the router...
(From the script that does my sig image)
04-01-2013 4:09 PM
Thanks for the suggestion - PHP is over my experience horizon and on the retirement bucket list to learn!
After a bit of scrabbling around, I got the following asp / vbscript to do the job. A bit Heath Robinson, but it works... others might find it useful. Effectively it parses the results of tracert.
Response.Buffer = true
url ="plus.net"
Set objWShell = CreateObject("WScript.Shell")
Set objCmd = objWShell.Exec("tracert -4 -h 4 -w 40 " & url)
strPResult = objCmd.StdOut.Readall()
Set objCmd = nothing:
Set objWShell = nothing
strResponseRows = split(strPResult, vbCRLF)
for i = 4 to ubound(strResponseRows)
if instr(strResponseRows(i),url)>0 then
strInterestingBit = mid(strResponseRows(i),33)
strResult = split(strInterestingBit," ")
strURL= split(strResult(0),".")
response.write strURL(0) & "<br>"
response.write strURL(1) & "<br>"
response.write strResult(1) & "<br>"
exit for
end if
next
Produces...
lo0-central10<br>pcl-ag01<br>[195.166.128.182]<br>
04-01-2013 4:17 PM
Quote from: townman If the AP / modem supported TelNet I might beable to extract the data from there, however they do not support TelNet.
You can enable telnet on the WAN interface of the 582n using:
:service system ifadd name TELNET group wan
:mlp role addpriv name Administrator access anyaccess service anyservice
:saveall
04-01-2013 7:44 PM
Edit: You'd think I'd know URLs for things that I've been involved in building 😕
04-01-2013 11:30 PM
Happy New Year to you...
Thanks for this contribution, even though it does not help me here. I've ditched the TG585v8 as I suspect it is part of the problem I'm toying with elsewhere with Anotherone. I do not have the 582n, not too sure it would help anyway other than exposing Bits & Tone data.
Do I correctly conclude that these commands make the TELENT interface remotely accessible ove rthe WAN interface? If so than this might offer the means of undertaking remote RouterStats data collecting in situations where (for whatever reasons) RouterStats cannot be run locally.
Cheers,
Kevin
07-01-2013 11:48 AM
Yeah, you'll be able to access your router remotely after running the telnet commands.
15-01-2013 8:12 PM
