ADSL2+ disconnect
Mardler
ADSL2+ disconnect
After 62 days rock solid performance, last night (September 12/13) the connection dropped:-
Time: 00:57:04
Error messages:-
pppd: No response to 3 echo requests
pppd: Serial link appears to be disconnected
The log then shows connection down.
Time: 00:57:09
Connection up.
This is a new one on me but it looks like an external error either exchange or PN.
Anyone else have a similar problem? Was it at PN's end?
5 REPLIES 5
Fixes: 388
Re: ADSL2+ disconnect
I wouldn't worry about a 5 second 'blip' - especially on an ADSL line.
Fixes: 585
In the early hours, likely caused by Openreach/BTw maintenance
outcast
Aspiring Champion
Fixes: 19
Given the timestamp, I would imagine that this is simply something as innocent as Openreach exchange DLM doing a quick re-sync, after nudging a slight change in the line's DSL power level to maintain what is probably a very good SNR margin (assumed from the previous 62 day up time), to compensate for the changing weather conditions as we move in to autumn.
outcast
Aspiring Champion
Fixes: 19
@Mardler  could check that by putting in the landline phone number in to https://status.zen.co.uk/broadband/
and seeing if there were any co-incident Openreach maintenance works under the sections -
  • Current/Recent Faults and Maintenance
  • Past Faults and Maintenance
Mardler
Thanks for the replies, folks.
The zen link was -ve but thanks, Outcast.
As yet I am not worried, just curious.
