ADSL2+ SNR target not reset
- Re: ADSL2+ SNR target not reset
14-04-2009 8:23 PM
I was hoping this would be reset when the trial went active as I had a problem phone that caused it to be set so high.
At the moment I'm have a 2 meg connection on a line that should support at least 3.5meg with my 56db attenuation.
Does this mean it's stuck since it didn't go back to 6db when the trial was activated for me?
Can it be manualy reset or am I stuck with this as it is?
So many questions
Shaun
14-04-2009 8:33 PM
14-04-2009 9:05 PM
Quote with my 56db attenuation
No way are you going to get a better download speed - it could even be reduced.
You might get a greater upstream rate though - which is good for P2P.
14-04-2009 9:55 PM
Called support and raised a ticket to see if BT will reset this back to a 6db profile.
14-04-2009 11:08 PM
One user (at least) is running with a 3dB target noise margin (link). The range on 21CN has been quoted as 3dB to 18dB.
David
14-04-2009 11:56 PM
hopefully once the 10 days have passed things will sort them selfs out but with the snr target staying at 12db when switched i cant see there being a 10 day training period to be honest
15-04-2009 12:16 PM
15-04-2009 12:58 PM
15-04-2009 4:07 PM
connection according to BT wholesales over the top bras settings
15-04-2009 5:21 PM
15-04-2009 5:43 PM
16-04-2009 4:30 PM
For some reason the DSLAM has decided to set a 18db target margin on my line which is killing my connection sync. If this isn't changed automatically in the next couple of days can this be manually reset?
James
16-04-2009 4:56 PM
Do you have any noise on your line thou ? this maybe a reason why they set a high target SNR.
Mark
16-04-2009 5:14 PM
My line certainly isn't great, however it's not so bad as to require a 18db target margin!
James
Moderator's Note: Full quote of previous post removed - Forum Rules. David (spraxyt)
16-04-2009 5:40 PM
