BT Speedtester
- BT Speedtester
BT Speedtester
08-04-2009 6:11 PM
http://www.speedtester.bt.com
Just trying on my test line in the office and at home which were both installed this week and getting speeds below 100kbps (other speedtests are fine) and had a customer saying the same so wondering if there's any pattern.
Tried Safar on the test line on a Mac and IE on my home line on Windows 2K. Would be useful to gather feedback on what works or doesn't work as the case may be say that we can raise it as an issue (or identify what combination of browser/OS works) so if a few people could give it a go would be appreciated.
Plusnet Technology
Re: BT Speedtester
08-04-2009 7:15 PM
i just tried to do the bt speed tester now i have bein switched to adsl2 but i keep getting system busy tried a few times but the same.
came here to ask if this norm on the first day of wbc upgrade
Re: BT Speedtester
08-04-2009 9:20 PM
B.
Re: BT Speedtester
08-04-2009 11:26 PM
Re: BT Speedtester
09-04-2009 12:07 AM
Re: BT Speedtester
09-04-2009 2:23 AM
It;s been giving rubbish results on ADSL and ADSL2+ for months/years
Re: BT Speedtester
09-04-2009 2:37 AM
1500kbps ish on a 3000kbps profile.
if my line keeps its current adsl2 sync rate going till tomoro daylight i can smell a 3500kbps profile coming
Re: BT Speedtester
09-04-2009 7:04 AM
Test1 comprises of Best Effort Test: -provides background information.
Your DSL connection rate: 8128 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
IP profile for your line is - 7150 kbps
Actual IP throughput achieved during the test was - 6280 kbps
my Broadband Speed
Today 07:00 6634 kbps (829kB/s) 381 kbps (47.6kB/s)
Re: BT Speedtester
09-04-2009 5:06 PM
Plusnet Technology
Re: BT Speedtester
09-04-2009 7:15 PM
time of test same as post time.
Quote Test1 comprises of Best Effort Test: -provides background information.
Your DSL connection rate: 3499 kbps(DOWN-STREAM), 871 kbps(UP-STREAM)
IP profile for your line is - 3000 kbps
Actual IP throughput achieved during the test was - 83 kbps
Today 19:16 2722 kbps (340kB/s) 742 kbps (92.8kB/s)
Re: BT Speedtester
09-04-2009 11:29 PM
Quote from: adamski69 Your DSL connection rate: 13636 kbps(DOWN-STREAM), 1092 kbps(UP-STREAM)
IP profile for your line is - 8000 kbps
Actual IP throughput achieved during the test was - 126 kbps
Re: BT Speedtester
10-04-2009 1:21 PM
Plusnet Technology
Re: BT Speedtester
10-04-2009 7:07 PM
Your DSL connection rate: 11269 kbps(DOWN-STREAM), 888 kbps(UP-STREAM)
IP profile for your line is - 9000 kbps
Actual IP throughput achieved during the test was - 57 kbps
That's on my first 21CN enabled line.
B.
Re: BT Speedtester
10-04-2009 7:09 PM
Re: BT Speedtester
12-04-2009 7:49 PM
One of the first things he said was "you know those BT speedtester results aren't reliable, don't you?"
