ADSL filter
- Re: ADSL filter
ADSL filter
27-03-2013 5:38 PM
I have just joined Plusnet and was previously with Talktalk. An enginer came a month ago to check the line and said we did not need filters on each telephone as we has a BT accelerator. Is this correct or should I use the filters ?
The broadfband and telephone seem to work fine without them.
Message 1 of 6
(1,296 Views)
5 REPLIES 5
Re: ADSL filter
27-03-2013 7:10 PM
EDIT
Message 2 of 6
(748 Views)
Re: ADSL filter
27-03-2013 7:16 PM
Quote from: apjashley1 He's correct. The filtering is done at the master socket if you've got two seperate outlets on the socket, one for ADSL and one for the phone.
Message 3 of 6
(748 Views)
Re: ADSL filter
27-03-2013 8:05 PM
That is most helpful -thank you.
Message 4 of 6
(748 Views)
Re: ADSL filter
27-03-2013 11:16 PM
Quote from: apjashley1 if you've got two seperate outlets on the socket, one for ADSL and one for the phone....
... then you don't need filters but you don't have a BT Accelerator. A BT Accelerator (formerly known as an i-Plate, item 2 in the picture here) does NOT obviate the need for filters. Note in the picture there are NOT two separate outlets on the socket.
Message 5 of 6
(748 Views)
Re: ADSL filter
28-03-2013 12:35 PM
Noted many thanks
Message 6 of 6
(748 Views)
