A question about fibre+homeplugs
- A question about fibre+homeplugs
29-09-2014 9:12 PM
A friend of mine has recently got fibre but wants to move their P.C and router upstairs out of reach of the modem, Is it possible to connect the router to the openreach modem via homeplugs?
Phone line>Open reach modem>Homeplug1. Homeplug2>Router>PC etc
Message 1 of 4
(733 Views)
3 REPLIES 3
Re: A question about fibre+homeplugs
30-09-2014 10:50 AM
Hi pint,
Theoretically this should be fine however it's possible that it could cause unwanted side effects so I it would be worth giving it a try, ideally with some borrowed home plugs before buying their own.
On a side note with this, if there are any issue/fault with the connection while in this configuration (regardless of the home plugs being the cause or not) it will have to be returned to the correct set up for the fault finding process in order to avoid any unwanted engineering charges.
Message 2 of 4
(404 Views)
30-09-2014 10:52 AM
Could they not leave the modem and router downstairs, then homeplugs up to the PC from there?
Message 3 of 4
(404 Views)
30-09-2014 12:39 PM
My homeplug master is connected to the router.
Message 4 of 4
(404 Views)
