40/10 or 80/20 which one?
- Re: 40/10 or 80/20 which one?
- « Previous
- 1
- 2
- Next »
11-06-2014 10:24 PM
12-06-2014 10:55 AM
As explained here: http://community.plus.net/library/browsing/fttc-dlm-what-it-is-how-it-works/ the only way we can get the speeds back up, is to ensure that your connection remains stable and (hopefully) error free and our speeds should return back to normal.
12-06-2014 11:00 AM
12-06-2014 11:12 AM
12-06-2014 11:14 AM
12-06-2014 11:18 AM
14-06-2014 9:26 AM
15-06-2014 12:17 PM
please tell me how this is not limited to 40/10, i simply dont believe what im being told, theres something not right and its that simple, so please do some further investingation.....
15-06-2014 12:34 PM
Please check your laptop or pc on wired setting and make sure the Lan Speed & Duplex set at 1.0 Gbps Full Duplex not 100 Mbps Full or Half Mbps. The smartphone/mobile phones does limited the speed on wifi.
16-06-2014 2:20 PM
Based on the outcome from the latest uploaded speed test your acceptable range is between 30.75Mbps - 38.44Mbps and your line is performing at 37.34Mbps. This is towards the top end of the acceptable range. You are definitely on 80/20 so there isn't much I can suggest regarding increasing your speed. If you're seeing a slight decrease in speed it may be due to an increase in uptake of connections in your cabinet and this isn't something that we can control, unfortunately.
If you do feel that the issues you're experiencing are due to a fault then you can raise this to us here: http://faults.plus.net
16-06-2014 5:18 PM
also if i do this will any discounts for loyalty that i have in place still be honored, namely the 18 month agreed discount and my referrals discount?
16-06-2014 5:21 PM
However ringing the Customer Options Team on Cancellations may give an acceptable result
23-06-2014 11:09 AM
also if i do this will any discounts for loyalty that i have in place still be honored, namely the 18 month agreed discount and my referrals discount?? "
as much as i appreciate jim's answer i would like a clarification and opinion of a plusnet member of staff to aid in this decision.
23-06-2014 11:15 AM
P.S - Your referrals will remain.
- « Previous
- 1
- 2
- Next »
