21CN Enablement
Re: 21CN Enablement
I believe its only the WBC that you need - the PSTN refers to Public Switched Telephone Network I believe, and thus relates to when BT will move the voice elements of your line onto their new network.
pnf
Re: 21CN Enablement
Thanks for the clarification James, much appreciated.
scootie
Re: 21CN Enablement
does any one know if bt have totaly redesigned the network when coming up with wbc by redesign i mean have they sorted how the system profiles your line ie waiting 3 days for your profile to go back to normall after just simply turning your router off and on with a gap of half hour. if it wasnt b.t's system then i would off thought some one was trying an april fools with this system.
as i belive llu dosent have this silly profiling system. so i can only hope that the wbc network dosent have this joke off a system.
HPsauce
Re: 21CN Enablement
Someone obviously thought it was a good idea at the time ( a few years back now) but since then things have moved on I guess.
James
Re: 21CN Enablement
Not completely.
It will use intelligent bRAS profiling.
ctech500
Re: 21CN Enablement
Quote from: Jameseh
Not completely.
oh No!!
What is "intelligent" BRAS profiling?
zubel
Re: 21CN Enablement
The same profiling as now, but with a new name!  Grin Grin
B.
James
Re: 21CN Enablement
It's quite simple really.  It's bRAS profiling.
But cleverer.
jelv
Fixes: 10
Re: 21CN Enablement
Quote from: ctech500
The same as now but it thinks about it before getting it wrong! Wink
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
ctech500
Re: 21CN Enablement
Giving the responses so far Intelligent BRAS is not an improvement but more of the same.
James
Re: 21CN Enablement
Hehe, don't listen to us, we're just being cynical.
I would be very surprised if the new implementation does not offer significant improvements to the current system.
jelv
Fixes: 10
Re: 21CN Enablement
It would have to be really bad not to!
scootie
Re: 21CN Enablement
Intelligent and b.t lol.    well if it isnt an improved profile system there will be alot of angry customers if there on an upto 24mb on wbc then they see there profile go down to somthing rubish for a few days.
as plus net will all ready know customers dont like it when there profiles r droped on a standard 8mb connection im sure the 24mb will cause a few head aches.
James
Re: 21CN Enablement
James knows all too well.
VileReynard
Fixes: 20
Re: 21CN Enablement
Why does the user end of a connection have a profile limiter whilst the server end doesn't?
Especially since most servers don't come near to 8Mbits/sec.
