21CN ADSL2 - How can i tell?
- Re: 21CN ADSL2 - How can i tell?
- « Previous
- Next »
25-01-2012 1:39 PM
thanks goldenadsl, i just brought the 20m one, think that should do the trick, will see how it goes when it gets here
Thanks again for everyones help
Message 31 of 34
(404 Views)
25-01-2012 1:52 PM
No problem mate. You will get it tomorrow first class. Let us know how it go when you turn off wi fi and use ethernet instead and I hope your pc or laptop does have Lan 10/100/1000 support as I use mine at Lan 1000.
Message 32 of 34
(404 Views)
26-01-2012 12:30 PM
so the ethernet cable arrived this morning, and fter turning off the wi fi and swaping to ethernet, the speeds have improved alot:
looks like i'll be sticking to the ethernet cable then
THanks again for ya help guys, and sorry if i came across abit stupid, lol
Message 33 of 34
(404 Views)
26-01-2012 1:39 PM
Glad to hear it, what router make and model do you have ? Can you use DMT Tool or RouterStats to tweak SNR to get extra 1 or 2 Megabit sync speed. Depend what SNR is on your downstream at the moment.
Plusnet and BT agree to set my line SNR at 3.3dB. And got speed of 15 Meg same as you on my old Netgear DG834N Rangemax Wireless Router and I tweak snr down to 2.2dB on the DMT Tool / Routerstat and my speed went up to 16 Meg from 15 Meg.
Because BT won't allow lower than 3dB snr as BT only do 3, 6, 9, 12 or 15dB snr at the exchange.
Message 34 of 34
(404 Views)
- « Previous
- Next »
