Speed variations on ADSL2+
- Re: Speed variations on ADSL2+
02-02-2016 3:03 PM
I'm on ADSL2+ and usually get a solid 16Mbps download speed. However over the last week or so the speed has varied from normal to atrocious and I'm not sure why The only recent change is a newer Netgear router - the old DGND3300 died and I had to get a Netgear D6400.
Link speed is good:
ADSL Link Downstream Upstream
Connection Speed 20745 kbps 1235 kbps
Line Attenuation 13.0 db 5.7 db
Noise Margin 3.1 db 5.8 db
The router usually maintains a rock solid connection. I cant even get on the btwholesale speed test page.
Anything that can be checked at the Plusnet end?
Link speed is good:
Message 1 of 4
(795 Views)
3 REPLIES 3
02-02-2016 3:09 PM
Is that wired or wireless?
If wireless you may have dropped on to a sometimes congested channel with the change of router.
Message 2 of 4
(501 Views)
02-02-2016 3:16 PM
The BT.com and BTWholesale.com websites seem to be down at the minute, so that's probably why you can't access the btwholesale speed tester.
Message 3 of 4
(501 Views)
02-02-2016 3:37 PM
Quote from: JayG Is that wired or wireless?
Thanks, I just had the same thought so have changed wireless channels and will see how that goes.
Message 4 of 4
(501 Views)
