Sorry.....But I am sick to death with the problems on my line.
- Sorry.....But I am sick to death with the problems...
Re: Sorry.....But I am sick to death with the problems on my line.
14-11-2012 9:25 AM
14-11-2012 11:49 AM
3Mb FTTC
14-11-2012 3:36 PM
14-11-2012 4:25 PM
Quote from: CWatters Sounds a bit like a water pump or similar? Any of the houses near you not on mains sewers and have their own micro sewage plant? Any need a pump to move the sewage up hill to get to the main sewer? Any new houses built around the time this started?
14-11-2012 4:28 PM
14-11-2012 4:30 PM
14-11-2012 4:37 PM
As for the timing... it probably depends more on whether it has to pump rainwater run-off as well as sewage. Is there any correlation with the weather?
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
14-11-2012 4:48 PM
The pumps tend to have a float switch which turns on at a set level and then pumps away most of the waste till it reaches a lower level, so they will run for an extended period at infrequent intervals (we used to have one beside our house where we lived many years ago).
Edit: A thought.
As the level in the storage tank drops the pump is going to have to work harder which might explain the sudden drop in noise margin when it turns on and then the gradual decrease over a period until it turns off.
Edit 2: Correct brain fade!
14-11-2012 4:55 PM
14-11-2012 5:15 PM
You meant "decrease" in margin? Otherwise, agreed a good possibility.
Edit: This could turn out to be a right load of ..........
14-11-2012 5:18 PM
More often than not I have observed my events Monday to Friday and not at the weekends (but not exclusively).
14-11-2012 5:45 PM
Quote from: Anotherone You meant "decrease" in margin? Otherwise, agreed a good possibility.
Whoops! I've corrected that.
15-11-2012 6:18 PM
Yes I did get an event........results....
1. 'Soft' power down of router. Event still audiable.
2. Turned of House mains on the fuse board. Event still audiable. Cause is not in my house then.
3. Go outside and have a walk around the front of my house and around. Event still audiable......but have narrowed the event being audiable down to an approximate area.
4. Walked up to sewage pump. Event NOT audiable. This is ruled out then.
I think this is the way forward...... to keep my tranny on all the time and keep it by myself in the house....at least then I get to hear the event as soon as it starts and this gives me the maximum time to investigate it before it ends.
RIGHT........so it is nothing in my house that is the cause. It is not the Sewage pumping station.
Lastly let me through this into the mix.........how about if I was to mention that one of my close neighbours is in to Amateur Radio (Radio Ham)...his house is smothered with a load of fecking massive aerials of all sizes and shapes. Could this be linked?
Alex
15-11-2012 7:40 PM
Quote from: alex7127 Lastly let me through this into the mix.........how about if I was to mention that one of my close neighbours is in to Amateur Radio (Radio Ham)...his house is smothered with a load of fecking massive aerials of all sizes and shapes. Could this be linked?
You're winding us up, surely? See http://www.rsars.org.uk/ELIBRARY/BBCONNECT.pdf
To quote the author
Quote Even if I powered down my own router, every time I went on the bands with QRP, I disconnected all the neighbouring broadband routers around me. If you think TVI makes you unpopular, this adds a whole new dimension.
15-11-2012 11:22 PM
Could this be a real problem?
Alex
