Sorry.....But I am sick to death with the problems on my line.
- Sorry.....But I am sick to death with the problems...
- « Previous
- Next »
Re: Sorry.....But I am sick to death with the problems on my line.
02-01-2013 2:26 PM
02-01-2013 3:43 PM
Just search on DGTeam and it brings up 834GTs and 834PNs.
02-01-2013 3:50 PM
04-01-2013 9:34 AM
04-01-2013 11:58 AM
04-01-2013 5:19 PM
04-01-2013 5:41 PM
Quote from: alex7127 It's back!!!!!
But at a completely different time of day, from what I remember. I know this is profoundly annoying and it looks as if you probably lost sync at the outset but the excess noise was not too severe thereafter. I wonder if your neighbour's connection survived or if he lost sync at the same time. The up time on his Netgear will be the time since the last PPP connection.
04-01-2013 5:50 PM
RR, as you've got an DG834PN if you could post the links for the interface to access the Line stats, errors and the Uptime for Alex, I know that would be extremely helpful to him.
04-01-2013 6:05 PM
When you log on you should arrive at the Router Status page. If not, click Router Status under Maintenance in the left hand menu column.
At the bottom of the Router Status page click the button marked Show Statistics. A pop-up windows will show you the attenuations, noise margins and the WAN uptime.
These instructions will work for any model of Netgear router I have encountered.
04-01-2013 6:13 PM
04-01-2013 10:27 PM
The telnet method probably needs
Quote ... you may find before you can telnet into a Netgear router that you need to enter the following in your browser URL bar:-
http://192.168.0.1/setup.cgi?todo=debug
That opens a window empty except for “Debug Enabled”. You can close that window immediately.
Having of course enabled telnet if your version of Windows defaults to Disabled.
I found the quickest and easiest was to DMT 8.07, tick "Special login" in the options - which sticks, (maybe you have to Save - I forget. That special login causes DMT to run that debug command without opening a useless Window), and select that adslctl info --stats command from a drop-down in tab2. That also sticks. So after the first time it is extremely rapid, with no typing. Just copy/paste from the results box then close DMT. (Running DMT for long alongside RouterStats which I had on 24/7 messes up).
04-01-2013 11:33 PM
You also need to enter the appropriate modem/router Login and Password and you can tick "autoconnect on startup" (as well as "special logon"). All that sticks as well.
Personally I'd use the info3 tab because it's bigger (you'll need to scroll up the list to get to adslctl info --stats ). Click Send, then highlight the whole text in the box with the cursor key and then <CTRL>C to copy it to the Clipboard and paste from there.
04-01-2013 11:40 PM
I checked the list on the site, then must have gone cross-eyed. Fixed, thanks :).
I used an 834PN for a long time, until I moved to FTTC.
04-01-2013 11:48 PM
Alex
- « Previous
- Next »
