Slow speeds this afternoon
sullys666
Our internet seems very slow and unresponsive this afternoon. Any reason why? Nothing has changed equipment wise at our end.
7 REPLIES 7
etdsaunders
Fixes: 7
Re: Slow speeds this afternoon
Hello,
Might be worth doing a gateway hop, login to router click disconnect and wait 10minutes and click connect. Sometimes gateways can cause slow speeds.
Raspberry Pi enthusiast!
If you Like it, give it a Thumbs_Up
sullys666
Probably best I leave that until the morning now, but that hopefully might help.
etdsaunders
Fixes: 7
Doing a gateway hop will not cause any problems or make DLM think there is a fault, providing you do it as stated above Cool_smiley
sullys666
Never like to do that sort of thing overnight. Prefer to do it when things like street lights aren't on. It does appear to have done the trick though, but we will see when my son goes on his XBox Live later Undecided
Mav
Fixes: 515
Moderator's note by Mike (Mav)
I have reset the fix to etdsaunders as setting a fix to your own problems without a detailed explanation as to the solution isn't helpful.
Forum Moderator and Customer
etdsaunders
Fixes: 7
@sullys666 doing a disconnect via the router does not drop the sync it only drops the PPP session so it won't effect speeds, doing a full reboot of the router would be a different story. Anyhow, glad the problem is fixed for now but keep us updated if it returns.
Did you know what gateway you was on prior to hopping?
sullys666
It was on pcl-bng01.
Now on pcl-bng03.
Seems ok at the moment.
