Slow internet after changing to bt home hub 3
Terry82517
Evening all, after suffering with bad wireless signal upstairs in my house with the plusnet router I acquired a home hub 3, now I get great signal all around the house but my internet has dropped to around 1.5mps  when it was previously around 5.5.
Anybody know of any settings changes that will help?
Regards terry
ADSL Line Status
Connection Information
Line state: Connected
Connection time: 0 days, 06:45:20
Downstream: 3 Mbps
Upstream: 448 Kbps
ADSL Settings
VPI/VCI: 0/38
Type: PPPoA
Modulation: G.992.1 Annex A
Latency type: Interleaved
Noise margin (Down/Up): 10.0 dB / 12.0 dB
Line attenuation (Down/Up): 36.5 dB / 27.5 dB
Output power (Down/Up): 19.7 dBm / 12.3 dBm
FEC Events (Down/Up): 25302 / 186
CRC Events (Down/Up): 45 / 21
HEC Events (Down/Up): 617 / 11
Error Seconds (Local/Remote): 15 / 10
10 REPLIES 10
JTaylor
Re: Slow internet after changing to bt home hub 3
Hey Terry
Sorry to hear this. The problem is actually caused by a fault on the phone line, which has resulted in the line being slowed down.
I've raised this to the supplier already who've given us an estimated repair time on 24.10.14 by midnight.
Hope this helps!
Terry82517
Thank you jack, must just be a coincidence.
Will I be informed when the fault is fixed?
Cheers terry
plusnettony
Plusnet Staff
Plusnet Staff
Fixes: 18
Jack raised a ticket on your account to monitor this. You should therefore get an SMS from our faults team once we get confirmation that it is working.
If you still have problems after that, just drop us a message and we'll advise further.
Tony
 Tony T
Terry82517
Hi, just a thought, I have no phones plugged in at home at all as I don't use a home phone, would this be the cause of the NDT fault? Or does not having a phone plugged in make no difference? Cheers
adamwalker
Fixes: 221
No, that wouldn't cause a no dial tone fault.
As the tone is generated by equipment at the local exchange it tends to imply a physical fault with the line.
Our line tests can usually pick that up without a handset needing to be plugged in.
 Adam Walker
Terry82517
Hi, I've still not heard anything regarding this fault and my internet is still slow. Cheers terry
Acassim
Hi Terry82517,
Sorry to hear that you haven't seen any change yet, just reviewing the fault it seems that this is still open even though the estimated repair date has passed. I'll see if I can give this a nudge for you now and find out why the fix hasn't been implemented yet.
You should have an update on the aforementioned support ticket as soon as we have some detail.
UPDATE
I've just been speaking with Openreach and it looks as though the fix was delayed due to resourcing in the area however they have resource allocated for the fix to go ahead today. Given this we should be able to see the problem repaired today and hopefully that will give you a shift in speeds.
Please do let us know how this goes for you!
Terry82517
Hi, the  no dial tone fault has been fixed, thank you.
But I'm still getting slow internet speeds, the no dial tone could has been a fault for years as I don't use a home phone so that doesn't seem to be the cause of the slow speeds. Regards terry
plusnettony
Plusnet Staff
Plusnet Staff
Fixes: 18
Your sync rate is a LOT better now. I've changed the speed profile at our end for you. Unfortunately, I can't see what the bRAS (BT profile) is set to (the tests keep failing).
Can you please re-connect to the internet for me. If you still have slow throughput speeds, can you then let me know and also perform the BT Speedtester and provide us with the results.
Thanks,
Tony
 Tony T
Terry82517
hi tony, the results are as follows
download 2.48
upload 0.36
ping 36.75
before i was getting about 8mb download speeds
regards terry
