RE your web page as been archived
- ADSL Broadband
- RE your web page as been archived
17-03-2008 3:13 PM
Since you fixed the reporting issue my web page as not gone down for the past 10 days
I did say I thought something had gone wrong and that 1000's of hits on my web page per hour was getting was incorrectly reported
Thanks to all the staff who helped resolve the issue
Michael
Re: RE your web page as been archived
19-03-2008 12:20 PM
Can sombody at Plusnet find a long standing solution for this problem (false reporting)?
Puddy
account=mjr99
19-03-2008 12:33 PM
19-03-2008 1:06 PM
my web counter has only moved 12 places and websats is showing a large % unknown hits.
As I have said before its a boring homepage, its 4 pages long has 9 jpeg photo's which are protected, I dont think anyone would nick pictures of my cat and few boring pages of planes.
I have had this webpage for over 10 years and have never had it taken down to over use before November 07!!!
The false reporting issue came to light after 4 or 5 us received the same abuse message with exactly the same bytes data overused, we had been told this has been happening since Novemeber last year, but it would seem its not been resolved
Bob Pullen was looking in to this problem for us before he went abroad now he back can he restart the investigation?
I do pay plusnet to host this site its not a free hosting
Puddy
puddy=mjr99
cp:blue Full quote of preceding post removed as per the link:rules mod:end
20-03-2008 10:05 AM
One proxy in Hong Kong hit my site 40,000 times in one day for a spacer GIF, compared to the site daily average of 20-30000 hits for all other requests.
Should one IP address stand out, you can serve it a 403 (forbidden) error using a .htaccess file. A 403 request only takes a few bytes out of your bandwidth.
Of course none of this helps if it is indeed false reporting...
20-03-2008 11:53 AM
www.pudy.co.uk/page 1
and another set of files look like below
/page
its the files listed "/page" that are getting all the hits yet it states I have referred 38180 hits from myself
again the same amount of hits are 91% unknown
the files listed "www.pudy.co.uk" only have 7 hits and thats correct with my web counter
In addition page's of my site have not been archived CSA page from web stats is still live
HELP
Puddy
can someone at plusnet give me call?
21-03-2008 7:10 AM
Does the page www.pudy.co.uk/page actually exist? If so how many bytes is it? Are the requests all for the page itself, or also for embedded graphics?
Edit:
Sorry, re-reading you post it's unclear if you are looking at the "raw" server logs or the stats as presented by webaliser?
22-03-2008 1:21 AM
the page www.puddy.co.uk/page do exist but page/2 etc dont and these are the ones with all the hits.
I did ask if somebody from plusnet could call me or pm and I have had no responce. I wanted my web site and all ftp data wiped so I could reset it up with the correct data. For some reason and cannot delete them myself
Puddy
cp:blue Full quote of preceding post removed mod:end
22-03-2008 1:09 PM
However, I have one suggestion that might help to finally get to the bottom of what's actually going on here if PN really can't do anything themselves. I have several acres of unused webspace on one of my A/Cs and it's just sitting there doing nothing particularly useful except for gathering dust. I also have detailed logfiles available daily for monitoring purposes because I don't like (and TBH don't trust) the PN stats available via the portal. It would not be the end of the world if this particular A/Cs webspace ended up being suspended if the resulting logfiles provide all the relevant information as to why this was done.
If you can zip up your entire site contents (including directory structure) and get them to me then I can bung it up on my webspace so that ALL accesses can be monitored to establish who or what is causing this problem. Once uploaded, all you would then need to do is add a suitable redirect in your .hta file to forward any and all attempts to access your site content in your webspace to a near identical location in my webspace. Something like this (although I'm notoriously good at making many fundamental mistakes in my .hta so this might not be 100% correct at the mo but it certainly can be fixed to do the 'right' thing if I currently have it wrong):
RewriteEngine on
RewriteBase /
RewriteRule ^(.*) http://www\.My_Account/PUDDY/$1 [R,L]
I'm sure there is a better (or more likely to work first time !) way of doing the redirect to a sub-directory in my webspace and someone will no doubt be quick to point it out but that's the sort of entry required anyway.
BTW, I'm pretty sure from past experience that there are permission issues when making large-scale changes to webspace and particularly when trying to delete directories with existing content. You can easily delete stuff starting at the lowest level and working upwards but not necessarily delete everything by trying to delete a top-level directory.
22-03-2008 5:27 PM
I don't think there's anything wrong with your rewrite code, but redirecting the requests to your webspace may not work if the clients(s) generating all the requests are poorly configured bots/proxies or malicious in intent, as they may not necessarily pursue the redirect to another domain. Most search engine spiders, for example, will not immediately follow a redirect, but will store the URL and may or may not check it later.
I may have missed it, but didn't see any mention of the raw logs being unavailable, and it would be far better if Puddy could access the these files via FTP under /logs from the top of his user web space. If they are not available to the user, PN should still be able to get hold of them. Even under webaliser/advanced webstats it should list the IP address or hostname under the "hostname" column with the number of hits.
I'd put my money on a "stuck" proxy or site ripper making endless requests from the same IP, which would be easy enough to spot in the logs.
22-03-2008 9:04 PM
This is a *very* long running sad and sorry tale but for reasons I can't quite remember, PN have previously stated that logfiles are not available to the user for this particular site. Your thoughts are basically my first comment absolutely ages ago: why all the poncing around and unhelpful trial and error suggestions from PN, just enable and check the logfiles for god sake and then remember that .hta is your friend !!
I still personally think that PN are being most unhelpful here (regardless of specific circumstances which I may not be fully aware of) because, unless I'm missing the point entirely and PN aren't being particularly up-front about what's going on behind the scenes, logfiles simply must be available within PN Towers at least in order to generate the basic portal stats for the user.
I'll put my money on some [expletive deleted] AOLers have been accessing the users' page(s) at some point in time and their stupid, brain dead and completely useless cache/proxy servers have all been grabbing the very same data several dozen times a day, every single day, ever since. Grrrrrrr, I absolutely hate AOL
But like you say, with logfiles it's easy to sort ... but without them it's a complete PITA.
23-03-2008 12:36 AM
With mod_rewrite, if the "R" flag is set on, the browser is instructed to make a new request. Removing it will make the redirect transparent to the user, but only if it's under the same subdomain; a redirect to your space would still be treated as a new request. In the absence of any raw logs though, it's still worth a punt, as there's little other option other than temporarily moving the domain to alternative webspace that has logging enabled or more active support than PN are offering.
AOL is definitely a candidate!
23-03-2008 8:24 AM
Still had no contact with them
no pm
no forum
no phone call
no reset of data
no advise thats useful
no investagtion ongoing
but as of today lots of bloody stickers telling them how good they are in uswitch 2008- but 2008 not finished yet so thats the end of good service for the rest of the year.
puddy
account=mjr99
25-03-2008 9:08 AM
Quote Still had no contact with them
no pm
- I've been out of the office for 4 days so apologies for not picking up your PM
Quote no forum
- As above
Quote no phone call
- As above
Quote no reset of data
- Reset of what data? If you would like the website restoring I can sort that out for you, alternatively if you had raised a ticket requesting this one of the CSC staff could have also done so.
Quote no advise thats useful
- I think this is a little harsh, we've given you different advice on this as have some other customers. The main piece of advice I've suggested is to use a .htaccess file to stop hotlinking of your images.
Quote no investagtion ongoing
- I've looked at the tickets on your account and we've responded to each one you've raised. In order to help investigate I've activated raw weblogs on your account, these should be available for your domain address tomorrow. Hopefully, as per Mikeb's suggestion, these will be helpful in pinning down the source of all the requests for your data.
25-03-2008 4:50 PM
Their are no hotlinked files on my webpage
If its being looked at I am happy for the time being!
Puddy
account problems =mjr99
- ADSL Broadband
