Throttled or not
- Throttled or not
Throttled or not
02-04-2008 3:10 PM
I am being throttled ? My broadband speed has been around 50kbps to 125kbps between the hours 18.00 24.00
just over a week now, normal 4000kbps to 7000kbps ( exchange 600 Meters )
I am nowhere near my usage limit, i always manage my use carefully, can you please check this out please
(ps) Keep up the good work
Message 1 of 4
(1,260 Views)
3 REPLIES 3
Re: Throttled or not
02-04-2008 3:19 PM
Hi Iain,
You are.
Broadband Plus carries a monthly peak usage allowance of 4GB. Once you have passed this amount, speeds are restricted to 128Kbps during peak times (4pm-12am).
Your usage is due to be reset on the 7th, which will see the restrictions lifted.
You are.
Message 2 of 4
(452 Views)
02-04-2008 3:20 PM
Out of interest, what does it say here
Also, if you run a BT speedtest at http://speedtester.bt.com what is the output (you may have to persevere, as the BT speedtester can be a little.... er... rubbish)
My immediate guess is that you've had a low resync event which has pushed your IP profile down. Have you fiddled with any of the connections to your router recently? Recently bought a new telephone, or had Sky installed?
B.
EDIT: Looks like it is usage related so my points aren't applicable anyway
B.
Message 3 of 4
(452 Views)
02-04-2008 6:26 PM
Thanks James for the reply I have discovered a network streaming problem
So used to having the fast connection
Message 4 of 4
(452 Views)
