Not Plusnet Line (BE*) need some advice please
- Re: Not Plusnet Line (BE*) need some advice please...
13-04-2009 4:54 PM
Hey,
This is not anything to do with plusnet and is not a fault but i'm a little confused regarding my BE* line.
I had a new line installed and i is a little longer than my plusnet line as is on different E side pair than my PN line (but all copper). Runs from Shenly (milton Keynes and i'm in bletchley
BUT my stats are really weird because i was under the impression that say a 60dB line on ADSL2+ would not see more than 2656kbps mow look at my stats.
And each mode has been tested for 48hrs with no major problem apart from a couple of resyncs but it always connected back at around the same speed
Now ADSL2 , got to say same results really nothing major is sync but maybe a few bps but attenuation is a bit lower @ 56.5 as expected
Now we come to plain old G.DMT , everywhere i have read shows this mode to have the lowest attenuation out of all modes , but no its does not for some reason its higher than ADSL2+ only 0.5db but it should be lower than ADSL2 (from experiance , i'm not sure what this could be , swapped filters , routers, RJ11 cables and its still the same also the very high sync and stability with such a long line . Maybe some tech dudes here can shed some light on this as i'm stumped
I'm happy with this line so far no grumbleing but still can not get my head round it
Stats for G.GMT
A Very Confused Mark
EDIT could be line issue ? line card or something 😕
Quote Mode: ADSL2+
Channel: Fast
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 6.4 6.1
Attn(dB): 60.0 34.9
Pwr(dBm): 19.2 12.4
Max(Kbps): 6433 949
Rate (Kbps): 5139 952
Quote Channel: FAST, Upstream rate = 945 Kbps, Downstream rate = 5170 Kbps
Link Power State: L0
Mode: ADSL2
Channel: Fast
Trellis: U:ON /D:ON
Down Up
SNR (dB): 6.3 6.3
Attn(dB): 56.5 35.0
Pwr(dBm): 19.1 12.4
Max(Kbps): 6446 949
Rate (Kbps): 5170 945
Stats for G.GMT
Quote Channel: FAST, Upstream rate = 900 Kbps, Downstream rate = 5158 Kbps
Mode: G.DMT
Channel: Fast
Trellis: ON
Down Up
SNR (dB): 6.1 7.0
Attn(dB): 60.5 31.5
Pwr(dBm): 19.1 12.1
Max(Kbps): 5191 1094
Rate (Kbps): 5158 900
Message 1 of 3
(843 Views)
2 REPLIES 2
13-04-2009 5:19 PM
Note that your ADSL2+ has an attenuation of +3dB over ADSL2 - which would seem to indicate the extra bandwidth of ADSL2+ isn't used.
So ADSL2+ = ADSL2 (as it should on such a long line, as you've lost all high frequencies)
Have you noticed that your downstream and upstreams noise margins are equal - weird?
Message 2 of 3
(398 Views)
13-04-2009 5:44 PM
They are not always like that it does move around , but what i can't understand is an att of 60dB for ADSL2+ sync 5mb, sorry forgot the sync lol "Channel: FAST, Upstream rate = 952 Kbps, Downstream rate = 5139 Kbps" and GDMt being the same more or less but the att on GDMT being higher . I have always read GDMT may = 52dB ADSL2+ can be 56dB always higher , not sure wat it is but something along the lines of tones and mhz
Message 3 of 3
(398 Views)
