New to Plusnet but no internet HELP!
- New to Plusnet but no internet HELP!
30-06-2008 11:16 AM
Orange is disconnected so phoned Plusnet who advised me that my BB switch over is now complete so I can go ahead and start browsing.
Set up my DLink DSL2640B Wireless Router and connected no probs so went ahead and setup wirelessly on the PS3, about 10 minutes later DISCONNECT. Tried reboot, reinstall, different cables, filters etc so phoned Plusnet to report the fault, they ran some tests which came back OK.
Friday 27th June
Router is still showing no DSL light after leaving it on all night (as Plusnet advised).
9am tried an alternative router which connected fine so plugged wireless router back in and got connected on that also.
Was out for the day so tried it again late afternoon but once again no DSL light on the router, tried rebooting (turning in on then off again) and it worked for about 10 minutes before disconnecting again, tried alternate router and same problem.
Rang Plusnet who escalated the fault , they rang me back later and went through the router settings etc and found no problems so advised me to leave it a couple of days to settle and then ring back.
Saturday 28th June
Tried turning the router on whenever I was passing and DSL light was never once illuminated.
Sunday 29th June
Rang Plusnet and advised them of no change so they said they'd run more tests and be in touch. Advised them that I’ve tried two different routers, three different filters, different cables and also connecting from my PS3 rather than the computer and still nothing – I have now tried everything I can to fix it.
Later tried my alternative router again and got on-line for 5-10 mins then lost connection and nothing.
Any advice? It's starting to pee me off now, its like I've got occasional broadband that comes and goes.
The only thing I can think of is that when they switched me over from Orange LLU (Orange install there own wiring at the exchange) back to BT they've somehow messed something up.
Whats my next step? Thanks for any help you can offer.
Re: New to Plusnet but no internet HELP!
30-06-2008 11:24 AM
I've just had a look at your ticket and it looks like you've literally just spoken to our guys to let them know that your router's back up and running so that we'll be able to run some testing. Once we've done that, I suspect it's likely that this will get fired across to BT.
I'd make a logical assumption that the jumpering work at the exchange hasn't been done properly by BT Openreach, which is causing your connection to become intermittent.
30-06-2008 2:13 PM
30-06-2008 2:14 PM
30-06-2008 2:25 PM
For a fully unbundled system the adsl and PSTN are coming from the same equipment, but jumpered through TAMS, to the line. If any part of the jumpering is faulty than both adsl and pstn will be down.
30-06-2008 2:29 PM
Am I missing something here?
30-06-2008 2:39 PM
Can't comment on your specific Tiscali problem other to say that now BT run more tests after jumpering to LLU before closing jobs down.
30-06-2008 2:44 PM
Quote from: itsme Believe the way the jumpering is done in the exchange it is posibble to have broadband without PSTN but not PSTN without broadband. So when no broadband is available is the phone still working? If so I would not have thought it's a intermittent fault caused by poor jumpering but more likely faulty equipment.
It can't be equipment failure as I've used two diferent routers, different cables, different filters and the connection drops out if I'm accessing the router via PC and PS3 so its neither of those,- plus all was fine until migration day. Unless you're talking about equipment at the exchange?
30-06-2008 2:46 PM
30-06-2008 2:47 PM
cp:quote
01-07-2008 10:57 AM
Unless BT messing about doing tests etc changed something??? either that or my Broadband just doesn’t like DLink routers.
Whatever, it’s working now and I'm leaving it as it is!
