Syncspeed dropping
Champnet
Syncspeed dropping
My syncspeed has dropped from 3500 to 2000kbps.
Tried the usual, master socket, replaced router  etc
Could someone give it a push ?
Thanks in anticipation
DM
James
Re: Syncspeed dropping
Hi DM,
Are you referring to your Sync speed or your IP Profile?
If the former, does it remain the same after all of those changes you have tried without any fluctuation?
Champnet
Thanks for very quick reply,
I was refereing to Syncspeed but just checked the IP profile and that has dropped to 2000k, reckon it was 3000 or 3500 a month ago.
DM
Champnet
Pevious BT tests show :
11:01 11/03/2008
Test1 comprises of Best Effort Test:  -provides background information.
    IP profile for your line is - 3500 kbps
    DSL connection rate: 832 kbps(UP-STREAM)  4576 kbps(DOWN-STREAM)
    Actual IP throughput achieved during the test was - 3166 kbps
19:24 28/03/2008
    IP profile for your line is - 4000 kbps
    DSL connection rate: 832 kbps(UP-STREAM)  4640 kbps(DOWN-STREAM)
    Actual IP throughput achieved during the test was - 3605 kbps
16:23 24/06/2008
    IP profile for your line is - 2500 kbps
    DSL connection rate: 832 kbps(UP-STREAM)  3456 kbps(DOWN-STREAM)
    Actual IP throughput achieved during the test was - 2244 kbps
16:30 01/07/2008
    Your DSL connection rate: 3360 kbps(DOWN-STREAM),  832 kbps(UP-STREAM)
    IP profile for your line is - 2000 kbps
    Actual IP throughput achieved during the test was - 1776 kbps
James
Right ok.
Can you tell us what your setup was for each of those tests?
Your ideal set up is always going to be connecting to the test socket behind the master socket.
The DSL Connection rate is the important bit to look at.
Champnet
Setup :
Master socket (not test) - 3Com router - switch - Computer
Latest test is with a standby Buffalo router
No config changes
