Erratic speeds
- Erratic speeds
Erratic speeds
01-07-2008 7:53 AM
No real problem as yet but only a couple of weeks after problems the speedcheck has started to drom from 6.4/7.2 down as low as 3000kbps. Not making a complaint, just interested what the speedtouch 780wl stats mean.
Bandwidth (Up/Down) [kbps/kbps]: 448 / 8,096
Data Transferred (Sent/Received) [MB/MB]: 109.46 / 129.83
Output Power (Up/Down) [dBm]: 12.0 / 7.5
Line Attenuation (Up/Down) [dB]: 0.5 / 2.0
SN Margin (Up/Down) [dB]: 23.0 / 13.0
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
If anybody has time to explain I would be grateful
Message 1 of 5
(1,029 Views)
4 REPLIES 4
Re: Erratic speeds
01-07-2008 8:00 AM
Crikey, do you live in the exchange or got a flat above it
No problem that I can see, throughput could be slowed if the exchange or sites you visit are busy at the time.
Message 2 of 5
(345 Views)
Re: Erratic speeds
01-07-2008 9:39 AM
I am about 300 metres from island exchange which is linked by microwave to main exchange. BT engineer got 7600kbps with 3 tests coupled to my master socket which is what I am plugged into with no extensions. I use a homeplug to couple to LAN so I'll try disconnecting that to see if there is any improvement.
Thanks - Mick
Thanks - Mick
Message 3 of 5
(345 Views)
Re: Erratic speeds
01-07-2008 9:41 AM
Hi Mick,
There's cetainly nothing wrong with your line. As has been suggested, it's possible that there some congestion going on during the slower times of the day.
Message 4 of 5
(345 Views)
Re: Erratic speeds
01-07-2008 9:50 AM
Thanks for that - mind at rest and no need to start checking wiring.
Mick
Mick
Message 5 of 5
(345 Views)
