New Router Attenuation
- ADSL Broadband
- New Router Attenuation
Re: New Router Attenuation
24-08-2010 8:58 AM
ADSL STATISTICS
Mode: ADSL2 PLUS
Type: ANNEX_A
Status: Showtime
Downstream Upstream
Rate (Kbps): 6531 kbps 444 kbps
SNR Margin (dB): 5.9 15.8
Attenuation (dB): 34.0 16.4
Output Power (dBm): 0.0 12.3
Super Frames: 2089295 2089295
RS Correctable Errors: 13004 0
RS Uncorrectable Errors: 0 65505
HEC Errors: 0 0
Total Cells: 810119 375504
Data Cells: 2245699 175415
Bit Errors: 0 0
I see that the SNR margin is back to what it was, otherwise it's Greek to me!!
24-08-2010 9:34 AM
24-08-2010 11:59 AM
1.93 by road
Although looking at the map I'm nearer than that as I'm the first house in the street and closest to the exchange.
24-08-2010 12:07 PM
The one thing we haven't suggested is trying the test socket with nothing else connected.
Can you try that and report the stats
Also try a different cable if you have one
24-08-2010 12:15 PM
I'll try the router in the test socket but having the router there permanently is not an option for me.
I've got a new fancy Dan cable coming from ADSL Nation so will install that.
24-08-2010 12:29 PM
Linky ????
24-08-2010 12:37 PM
http://www.adslnation.com/phpapps/catalog/product_info.php?cPath=21&products_id=120
24-08-2010 12:51 PM
Quote from: Oldjim Which would seem to indicate that the lower attenuation is more correct but then the speeds are far too low
Banded profile?
24-08-2010 12:52 PM
Vigor 130 modem, pfSense 2.4.5-p1 router, 5 WAPs, Devolo dLAN 500, Gigaset N300A-IP VoIP DECT
24-08-2010 12:52 PM
24-08-2010 12:53 PM
24-08-2010 12:54 PM
24-08-2010 1:09 PM
24-08-2010 1:55 PM
24-08-2010 2:01 PM
