Messages regarding fault
- Re: Messages regarding fault
23-07-2015 10:06 PM
how do I write a message regarding faults without it being an e mail. I can see all closed messages but cannot open a new one. Many thanks.
Message 1 of 3
(554 Views)
2 REPLIES 2
23-07-2015 10:37 PM
You dont say what sort of fault - I assume it is Broadband so start here
http://www.plus.net/support/broadband/bbfaults/index.shtml?supporta=connectionproblems
Did you read the First "Sticky" post in this forum?
Message 2 of 3
(346 Views)
23-07-2015 11:15 PM
If it's broadband, the link cedlor gave will take you to the troubleshooter. https://faults.plus.net/ will take you there as well (both via a login).
However, can you hear/have you heard any crackling or other noises on the line when using the phone? Have you had any problems with incoming or outgoing calls? If the answer is yes, it will also affect your broadband, but you need to report a Phone Fault instead.
Message 3 of 3
(346 Views)
