Heavy Data Usage
- Heavy Data Usage
Heavy Data Usage
27-04-2011 9:52 PM
- Run the wireless network with all computers switched off to see if anyone else was using the network, the result was no generated traffic (as expected since all security features are used).
- One computer was found to be generating the traffic. Carried out a full scan using the installed Norton Internet Security, without any malware being found.
- Carried out a more intense scan using Norton Power Eraser, but it did not find any malware either.
- Contacted Norton Support who carried out checks lasting over an hour and the conclusion reached was no malware on computer.
I was advised to install Wire Shark and send in some results. I did this and got the reply that this was not the best test for the problem with the computer. Plus net support suggested installing DU meter, I have tried this and can see traffic going in and out, there seems to be more inward traffic than outward traffic. When monitoring the internet traffic, there is not any other applications open, I have tried the tests using the computer connected wireless to the router and wired, the results are the same. The heavy traffic starts a few minutes after logging on to the computer.
Can you help?
Re: Heavy Data Usage
27-04-2011 10:11 PM
Next run some of the much better anti-malware / anti-virus scanners around
Install and run Microsoft security essentials (far better than norton and much less resource hungry) and run a full scan
Run malwarebytes
Run spybot search and destroy
Install process explorer - this allows you to see a lot more about what is running on your PC, including what network connections each process has open.
Your router may show active sessions which may give you IP and port numbers which you can check up on.
Some of the dos based tools can tell you what is using the network. Try netstat -ano which shows open / waiting ports. The -o also shows the PID which you can find the process in question in process explorer.
27-04-2011 10:14 PM
You could also try opening a cmd box (run it as administrator) and running the command
netstat -b
That will show you the executables associated with all the open ports.
27-04-2011 10:30 PM
Quote from: Peter First uninstall norton as it is one of the worse packages around... Your PC will thank you Note: you may need to run the Norton removal tool to actually get rid of all the stuff the uninstaller leaves behind
This is completely incorrect
The latest versions of Norton are not resource hungry and overall it gives better protection than MSE http://www.av-test.org/certifications.php
27-04-2011 10:41 PM
27-04-2011 11:04 PM
27-04-2011 11:27 PM
With the help of some members of this forum, I narrowed the problem to the settings of the Google toolbar that somehow had reset to sent statistical information to Google. Your problem may be the same
28-04-2011 5:16 AM
Quote from: Oldjim
I'd say the latest versions of Norton are not so resource-hungry as those of a few years ago but it's still not that great. But I don't see that Norton is more data-hungry than other security software, which is the point at issue here.
If you are familiar with HijackThis http://free.antivirus.com/hijackthis/ you could run a scan and post the log file here so we could comment on what programs you are running in the background that might be causing the problem.
29-04-2011 10:22 PM
Note to fxbronte, unfortunately, this computer does not have the Google toolbar installed so I am looking for a different solution.
Since my first request for help I have carried out a scan with the computer in safe mode and there still has not been any malware found.
The results from running DU Meter show that the incoming traffic is averaging approximately 350Kbs all the time.
30-04-2011 10:30 AM
Quote from: HarryR The results from running DU Meter show that the incoming traffic is averaging approximately 350Kbs all the time.
If that is happening consistently, even when you think it ought to be sitting idle, then just install Wireshark and capture a trace - from that you'll (we'll) be able to see where the traffic is coming from - possibly exactly what it contains - and from that determine what is pulling it in.
Mathew
30-04-2011 8:01 PM
30-04-2011 8:17 PM
30-04-2011 8:28 PM
Mathew
30-04-2011 8:44 PM
30-04-2011 8:55 PM
