Heavy Data Usage
- Heavy Data Usage
Re: Heavy Data Usage
30-04-2011 8:57 PM
If you're feeling up to it I think a network capture using Wireshark would be helpful as we would then be able to peek inside the packets to see what the actual traffic is, in particular what sites are being requested via Akamai. Happy to walk you through doing this if you like.
Mathew
30-04-2011 9:26 PM
Have a read here http://stream-recorder.com/forum/akamai-netsession-interface-and-disalbe-t7217.html
30-04-2011 9:37 PM
Quote Some of the dos based tools can tell you what is using the network. Try netstat -ano which shows open / waiting ports. The -o also shows the PID which you can find the process in question in process explorer.
With the PID you can find what process is using each of the network connections
30-04-2011 9:59 PM
Mathew
30-04-2011 10:32 PM
I have checked for the presence of Akamai on the computer using the information obtained by following the link from oldjim, but it does not seem to be on the computer.
01-05-2011 12:58 AM
Quote from: HarryR You do not seem to be able to send Wireshark files in their native format
You can save the dump in a libpcap file; a standard file format that can be read by most packet analysers.
However, Peter's suggestion of finding the PID's, and presumably identifying the named processes with task manager (I don't use Windows much not sure if there's a CLI equivalent), would likely cut to the chase.
From a quick glance at the PDF there seems to be a regular sequence of local UPnP traffic but the native libpcap dump will give a better indication of how much a proportion this represents.
Mathew
01-05-2011 8:41 AM
Have you tried closing the Windows sidebar? Many of the gadgets update themselves by communication with an internet server so a faulty gadget might conceivably run amok and start demanding huge quantities of data.
01-05-2011 8:51 AM
No. Time Source Destination Protocol Info
26 0.089999 192.168.0.2 88.221.84.72 HTTP GET /defs/dm/symcdefsi3264.exe HTTP/1.1
183 1.278020 192.168.0.2 88.221.84.72 HTTP GET /defs/dm/symcdefsi3264.exe HTTP/1.1
339 2.466048 192.168.0.2 88.221.84.72 HTTP GET /defs/dm/symcdefsi3264.exe HTTP/1.1
It repeats at regular intervals. My guess is that Norton (Symantec) has got stuck in a loop and is downloading updated definitions over and over and over again, but never manages to install them correctly.
01-05-2011 10:13 AM
01-05-2011 8:57 PM
Quote from: ReedRichards However I would have thought it is perfectly normal for security software to check for updated definitions at regular intervals.
This is every second though, at least for the 20s snapshot window that we've been given.
Mathew
02-05-2011 12:04 PM
02-05-2011 1:30 PM
02-05-2011 2:54 PM
02-05-2011 4:46 PM
02-05-2011 4:47 PM
