Quote from: HarryR |
Here is the netstat –ano capture how do you decode the PIDs?
As I explained earlier,
process explorer shows the pid of any process running. Just match the pid from the netstat output to the process. You can also double click on the process to get more info, including a list of network connections on the TCP/IP tab.
