Fibre logistics
- Fibre logistics
- « Previous
- 1
- 2
- Next »
Re: Fibre logistics
23-10-2013 8:12 PM
Message 16 of 22
(815 Views)
Re: Fibre logistics
23-10-2013 11:43 PM
Hi Strat
Many thanks for the picture however that is surely the RJ45 type not the RJ11 6 pin one which AFAIK I should be changing over my current BT plug (RJ45 like) ones I have now, as per Axemurderers advice???
Message 17 of 22
(815 Views)
Re: Fibre logistics
23-10-2013 11:52 PM
Message 18 of 22
(815 Views)
Re: Fibre logistics
24-10-2013 7:58 PM
@ Apprentice ~ many thanks for the added input
Having had a good gander at various sources as I understand it (was going to dig out an old unused RJ11 modem cable) the modem RJ11 uses more properly called 6P4C plugs i.e. 6 pin/4 connections. But the modem wiring only uses the 2 central pins 3 & 4 (I did say I was going to find and old 'supplied' one to look at and disassemble ) so the question is:- does the FTTC modem use this original type RJ11 wiring or does it require the further wires connected???
FWIW I think when I connected the BT plugs I am using now I did only connect 2 wires but these were connected to the 2 outer pins 2 & 5
TIA for the added insight and that I have understood the wiring correctly
Message 19 of 22
(815 Views)
Re: Fibre logistics
24-10-2013 8:41 PM
Not sure if it helps but Over a short run of Cat5e it's possible to use a set of passive POE injector/splitters to remotely power the modem, at least with the Huawei one it is.
The router can be upto 100M away from the modem providing you have a long enough Cat5e/Cat6 cable (I actually suspect you could get away with over 100M but that would be outside the Specs)
Message 20 of 22
(815 Views)
Re: Fibre logistics
25-10-2013 12:30 AM
Just some thinking out loud
I have measured the diameter of the telephone UTP cable in use now and it is 5mm, now CAT6 is 6.5mm but CAT5e is 5.25mm so without making the holes in ceiling & floor bigger it should be possible to pull through a CAT5e. The route is not direct i.e. a couple of low radius turns so all should be well as the current cable "pulls" without snagging or strain . Now I might do that sooner rather than later and wire it up to either RJ11 or BT plugs in the meantime until the FTTC service arrives By doing this bit of pre planning there should be no headaches and stroppy OR engineer to cope with on the day when it arrives ............................all I will need to is cut off the RJ11 (or BT plugs) and strip/crimp on the RJ45's
Oh, as I understand it CAT5e is good for Gigabit speeds so will not be an impediment to the Fibre speeds from the modem to the Router
Edit - it is this Maplin one I found http://www.maplin.co.uk/cat-5e-network-cable-utp-stranded-13230 that OK???
Message 21 of 22
(815 Views)
Re: Fibre logistics
29-10-2013 6:59 PM
@Routefinder
If you stick with your existing modem cable, you only need two wires connected in your RJ11/6P4C. If you decide to pull through an ethernet cable that Maplin one will be fine.
Message 22 of 22
(815 Views)
- « Previous
- 1
- 2
- Next »
