FTTC DLM Reset
- FTTC DLM Reset
FTTC DLM Reset
10-09-2014 1:25 PM
I just wondering if Plusnet and other isp's willing to ask BT to have FTTC DLM reset once a month automatically without the need of engineer to go to the cabinet and reset DLM. Can they do that?
Re: FTTC DLM Reset
10-09-2014 1:49 PM
Re: FTTC DLM Reset
10-09-2014 2:16 PM
Re: FTTC DLM Reset
10-09-2014 2:17 PM
Re: FTTC DLM Reset
10-09-2014 2:24 PM
If you spent some of your time learning about the way thinks worked and why, then maybe you wouldn't make unrealistic requests and your understanding and your depth of knowledge would be better.
Re: FTTC DLM Reset
10-09-2014 2:33 PM
Quote And just like DLM on ADSL it's stabilising the line in those circumstances.
So why did my DLM reset earlier this year increase my d/l speed from 30 to 45?
Re: FTTC DLM Reset
10-09-2014 3:29 PM
The best example I can think of is, say a connection suffered a lot of noise due to lightning and lost sync, it very often will sync at a lower speed if the static is still present. That won't change until there is a resync for some reason. Even power dips can cause that.
Did you perchance try logging into the Router to drop your PPP session and then turn it & the modem off for an hour or so? (Remembering to login and click Connect when you boot everything up again).
Re: FTTC DLM Reset
10-09-2014 3:56 PM
However if a line has ongoing/chronic issues, resetting DLM will only make DLM relent temporarily and may also cause packetloss if errors are heavy on the line without DLM. In this situation you dont need a DLM reset you need the core problem fixing.
Re: FTTC DLM Reset
10-09-2014 3:59 PM
Quote from: chrcoluk DLM can be unhelpful e.g. on a line thats normally stable, but has a one of burst of problems
Realistically though, how often do you think that happens?
Re: FTTC DLM Reset
10-09-2014 5:28 PM
