Broadband Fault & Order Support Guides
Pettitto
Fixes: 5
I’ve reviewed the supporting documentation surrounding broadband faults. I’ve taken some time to write some in depth and easy to read documentation on how broadband faults might arise, and what it is we do as your Internet Service Provider to investigate and resolve such issues.
If you believe there is anything missing from these guides, or have a question generally, please comment on the specific guide and I’ll do my best to answer any questions you may have. Please see below for links to the relevant guides.
I have a fault
No Sync (NSC) || Flashing 'Broadband' Light
Frequent Disconnection (DCN)
Speed (EPP)
Authentication (Auth) || 'Internet' Light Red?
Fault Locations
Broadband Network
Banding Guide
Our Testing
Fibre Faults Guide
Available options for setting noise margin, interleaving etc.
How Fibre DLM works
Reconnecting after a Major Service Outage
Moderator's note by Mike (Mav): Links fixed
3 REPLIES 3
Oldjim
Fixes: 63
Re: Broadband Fault Support Guides
Made temporary sticky as otherwise it could easily get lost
Oldjim
Fixes: 63
Link added to BT document giving options and methods for setting noise margin, interleaving, retrain, etc.
Pettitto
Fixes: 5
Re: Broadband Fault & Order Support Guides
Added a link for the guide to reconnecting manually via the router following an MSO/MSF
