Current Line Speed Not Set( SOLVED)
- Current Line Speed Not Set( SOLVED)
23-08-2010 7:39 PM
Just got my broadband activated today and came across this, Is It normal when your newly activated? Or will It only be set after the 10 day initial line checking?
If life gives you lemons, make lemonade.
Message 1 of 7
(1,055 Views)
6 REPLIES 6
Re: Current Line Speed Not Set
23-08-2010 8:23 PM
that generally follows the speed that BT profile you at, so you wont see anything until PN get the first report from BT
Message 2 of 7
(539 Views)
23-08-2010 10:17 PM
Okay cokey thanks for that Pierre-Pierre.
Message 3 of 7
(539 Views)
03-09-2010 1:16 PM
Can Plusnet take a look at this and fix It please, I should be finished my 10 day line training period and still no IP profile!
Message 4 of 7
(539 Views)
03-09-2010 1:22 PM
Hi Steve M,
I've just set your line profile to 7150. You should see that now.
Jojo
Jojo
Message 5 of 7
(539 Views)
03-09-2010 1:29 PM
JoJo your a star, Thankyou
Message 6 of 7
(539 Views)
Re: Current Line Speed Not Set( SOLVED)
03-09-2010 1:37 PM
I know
Message 7 of 7
(539 Views)
