Re: Affect on speeds of the Plusnet profile
- Feedback
- Plusnet Feedback
- Re: Affect on speeds of the Plusnet profile
30-03-2014 6:35 PM
1. increase my line speed
2. wait for plusnet profile to increase
3. decrease my line speed
4. measure the throughput before the plusnet profile decreases
So far I have succeeded with step 1, and have been waiting for step 2, which is guaranteed to happen in a timely and reliable manner (hashtag sarcasm). An unexpected by-product of the experiment so far is that my line seems adequately stable at the higher speed.
[tt]US Connection Rate: 882 DS Connection Rate: 4019
DS Line Attenuation: 57.9 DS Margin: 6.1
US Line Attenuation: 36.3 US Margin: 5.2[/tt]
13-04-2014 7:17 AM
PN profile 3.5
sync 4059
throughput 403KiB/s - 158385999 bytes in 6m 23s
PN profile 3.5
sync 3739
throughput 392KB/s - 158385999 bytes in 6m 34s
I was downloading firefox-28.0-3.fc20.src.rpm with wget.
I didn't do some worthless ping test at the same time because that would be completely missing the point of this thread - that the PN profile seems to limit my speed to less than what the line is evidently capable of. Also because I don't particularly care about the performance of ICMP echo requests and replies.
13-04-2014 10:49 AM
Your ip profile is always 88.2% of your sync rate. our profile matches BT's (the majority of the time)
On the second one the profile hasn't updated yet.
14-04-2014 1:05 PM
Quote from: Ed On the second one the profile hasn't updated yet.
Yes that was the whole idea of those measurements. I'm waiting to do the third test, once the Plusnet profile updates to 3.2. Then the throughput won't be the line speed of 392KiB/s, it will go down to I expect about 360KiB/s. The Plusnet profile may be set to the same number as the BTWholesale profile, but its affect on the speed is not the same.
392KiB/s is approximately 3.21Mbit/s which is just under the BTWholesale 88.2% IP profile for the sync speed of 3739.
Perhaps not all the layers of protocols encapsulated within other protocols are not being accounted for correctly when applying the PN profile, or perhaps Plusnet just decide to knock 5% off all ADSL customers' speeds to reduce Plusnet's bandwidth requirements in the hope people won't notice the slight discrepancy.
16-04-2014 7:12 AM
PN profile 3.5
Limited by PN profile: yes
sync 4059
throughput 403KiB/s - 158385999 bytes in 6m 23s (3.308Mbit/s)
PN profile 3.5
Limited by PN profile: no
sync 3739
throughput 392KB/s - 158385999 bytes in 6m 34s (3.216Mbit/s)
PN profile 3.2
sync 3739
throughput 368KiB/s - 158385999 bytes in 7m 0s (3.017Mbit/s)
Not quite as bad as I thought but the difference is still greater than the 100Kb rounding margin given. So, why can't the PN profile limit the speed to what the line is actually capable of? How do you get away with calling it Unlimited broadband?
And it's going to be difficult to try to explain away the difference by arguing that the speedtester is measuring the speed wrong, since I didn't use a speedtest website, so unless you are going to try to argue that it didn't actually take wget 26 seconds longer to download the same file. Perhaps a load of good sounding but meaningless technical gibberish about protocol overheads, which are exactly the same for all of the three measurements? Oh dear, I did all the tests over wireless, perhaps you would like to blame the wireless?
16-04-2014 9:33 AM
Quote from: ejs How do you get away with calling it Unlimited broadband?
It's Unlimited due to no usage restrictions not speed.
The PN profile eventually updates, so I can do the third test.
Quote PN profile 3.5
sync 4059
PN profile 3.5
sync 3739
PN profile 3.2
sync 3739
I'll flag this up with Dave, he's not in today though.
Quote Oh dear, I did all the tests over wireless, perhaps you would like to blame the wireless?
Regardless, it is always more accurate over a wired connection.
16-04-2014 11:21 AM
16-04-2014 12:31 PM
Quote from: Chris
Even that is factually incorrect. Calling it "Unlimited Broadband" requires both speeds and usage to have no restrictions.
I can't do another test right now, probably the next convenient time will be early tomorrow morning, plus I already put by sync speed back up.
16-04-2014 10:01 PM
After reconnecting and ending up on pcl-ag02, I saw that the previous file download was not running at a completely maximum speed 100% of the time, so I had to download something else that did.
[tt]wget http://download.microsoft.com/download/6/E/F/6EFA2958-EF2B-4DD1-B3BC-B891CB7C83DC/Windows6.0-KB94782...
--2014-04-16 21:34:50-- http://download.microsoft.com/download/6/E/F/6EFA2958-EF2B-4DD1-B3BC-B891CB7C83DC/Windows6.0-KB94782...
Resolving download.microsoft.com... 23.61.255.25, 23.61.255.17
Connecting to download.microsoft.com|23.61.255.25|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 150518130 (144M) [application/octet-stream]
Saving to: ‘Windows6.0-KB947821-v33-x86.msu’
100%[======================================>] 150,518,130 370KB/s in 6m 38s
2014-04-16 21:41:28 (369 KB/s) - ‘Windows6.0-KB947821-v33-x86.msu’ saved [150518130/150518130][/tt]
I was not planning to mess about testing every single gateway, moving my sync speed up or down, and then waiting a few days for my PN profile to go up or down. And I already reproduced the same thing back in August 2013, which presumably pre-dates your new gateway.
17-04-2014 7:03 AM
[tt]--2014-04-17 06:42:26-- http://www.mirrorservice.org/sites/dl.fedoraproject.org/pub/fedora/linux/updates/20/SRPMS/firefox-28...
Resolving www.mirrorservice.org... 212.219.56.184
Connecting to www.mirrorservice.org|212.219.56.184|:80... connected.
Length: 158385999 (151M) [application/x-redhat-package-manager]
Saving to: ‘firefox-28.0-3.fc20.src.rpm’
100%[======================================>] 158,385,999 366KB/s in 7m 2s
2014-04-17 06:49:29 (367 KB/s) - ‘firefox-28.0-3.fc20.src.rpm’ saved [158385999/158385999]
--2014-04-17 06:49:37-- http://download.microsoft.com/download/6/E/F/6EFA2958-EF2B-4DD1-B3BC-B891CB7C83DC/Windows6.0-KB94782...
100%[======================================>] 150,518,130 366KB/s in 6m 41s
2014-04-17 06:56:19 (366 KB/s) - ‘Windows6.0-KB947821-v33-x86.msu’ saved [150518130/150518130][/tt]
And I watched those downloads to check they ran at full speed the whole time, which they did. I conclude the difference between gateways so small that it is only just measurable and cannot possible account for the at least 22 KiB/s lost due to the PN profile.
17-04-2014 10:15 AM
Ex-Plusnet Jobsbody
17-04-2014 10:21 AM
If you want to start this in a new thread it might be better to split off the relevant posts from here
If you can advise the ones you would like splitting off either in this thread or by PM I will do it
18-04-2014 10:06 AM
18-04-2014 10:38 AM
If you would like the title changing please advise
I might add that this thread brings everything back to my first post in the original thread - and no I am not going to try to sort it out
27-04-2014 10:03 PM
PN profile 3.5
sync 4059
IP layer: 162725359 bytes in 6m 23s = 3.399 Mbit/s
PN profile 3.5
sync 3739 (88.2% gives BT Profile of 3.297 Mbit/s)
IP layer: 162725359 bytes in 6m 34s = 3.304 Mbit/s
PN profile 3.2
sync 3739
IP layer: 162725359 bytes in 7m 0s = 3.100 Mbit/s
Those figures look almost as if the plusnet profile is the BT profile, rounded down to the nearest 100k, and then has 100k subtracted.
(I also just looked at some of the statistics in wireshark, but wireshark indicated 164244640 bytes which looks like it was including the 14 byte ethernet layer on each packet.)
- Feedback
- Plusnet Feedback
