V6 on the TG589 v3
HairyMcbiker
All Star
Fixes: 21
V6 on the TG589 v3
Well so far I can log in with V4 ONLY.
The menus are not allowing me to enable v6.
TCP/IPv6 Settings
IPv6 State: Disabled
Stateless Address Autoconfiguration: Disabled
IPv6 Address: -
IPv6 Default Gateway: -
Local Interface ID: -
Remote Interface ID: -
DNS Server 1: -
I have tried telnet and set the ip config ipv6 to enabled. Rebooted but still no luck.
Any clues?
116 REPLIES 116
MJN
Seasoned Pro
Fixes: 5
Re: V6 on the TG589 v3
Just to confirm, you are using the trial login credentials? (Worth checking TR069 hasn't overwritten them too with your default account details - it hadn't on mine but I'm not familiar with the mechanics of how it works).
The 'IPv6 State:  Disabled' line suggests however that the CLI config didn't work. What were the exact commands you entered? A reboot shouldn't be required - the ppp ifdetach/ifattach components should cycle the PPP connection with the new config anyway.
HairyMcbiker
All Star
Fixes: 21
Yep it tried to overwrite them but I replaced them.
Just used jelv's instructions for the older one and it seems to have worked.
TCP/IPv6 Settings
IPv6 State: Enabled
IPv6 Address: fe80::a6b1xxxx::xxxx:142e/64
IPv6 Default Gateway: fe80::90:xxxx:xxxxab17
HairyMcbiker
All Star
Fixes: 21
Well it CLAIMS to be connected but all the tests return ipv4.
Rebooted pc have both ipv4 & v6 ip's.
Router tests say:
Test Results
Test Succeeded DSL
Test Succeeded Ethernet
Test Succeeded PPP
Test Succeeded Native IPv4
Test Succeeded Native IPv6
Test Succeeded Internet
Enabled/OKConnectivity to IPv4 Gateway (195.166.128.189)
Enabled/OKConnectivity to IPv6 Gateway (fe80::90:1a00:xxxx)
Enabled/OKConnectivity to DNS Server 1 (212.159.6.10)
Enabled/OKConnectivity to DNS Server 2 (212.159.6.9)
But the ip6 test pages show ipv4 ONLY.
pjmarsh
Fixes: 24
What does your PC show?  On my Billion 7800N it seemed to be a problem with what the router was passing/not passing on (see here for details on that one).  Could it be anything similar?
Phil
HairyMcbiker
All Star
Fixes: 21
Not sure what I should be seeing. Never used ipv6 before...
In the router I have:
TCP/IPv6 Configuration
IPv6 State: Enabled
Advertising prefix: --
Use Stateless DHCPv6 Server: Enabled
Should that autoconf be ENABLED?
pjmarsh
Fixes: 24
I'm not sure tbh.  This is my first venture into ipv6, though I've been following it for a while.  On the other thread (reply #3), in the Network Connection Details screenshot, when it was working I got entries for "IPv6 Address" added at the bottom, and both the "IPv6 DNS" and "IPv6 gateway" had values.
I'm not at home at the moment to give a screenshot.
Your advertising prefix possibly seems similar to my "Interface Address / Prefix length" which I had to enter the correct value in to get it to work.
Phil
HairyMcbiker
All Star
Fixes: 21
Can't change the advertising prefix
Only option on the web page is enable/disable stateless.
MJN
Seasoned Pro
Fixes: 5
Quote from: Hairy
You need to provide a bit more clarity. For example, post the output of the results from test-ipv6.com.
For the most basic test, also try an IPv6 ping from the router:
ping proto=ip addr=2001:4860:4860::8888
HairyMcbiker
All Star
Fixes: 21
ip6 test
When both protocols are available, your browser uses
IPv4
Your internet connection is not IPv6 capable
unable to contact IPv6 test server
router:
{Administrator}=>ping proto=ip addr=2001:4860:4860::8888
Legend : Pingv6 successful(!)
        Pingv6 Timeout(.)
        Hit ctrl-g to abort...
--- Pingv6 statistics ---
5 packet(s) transmitted, 0 successful, 100% packet loss
MJN
Seasoned Pro
Fixes: 5
It's worth case focussing on the router as if it doesn't have IPv6 connectivity obviously the clients won't either.
Can you ping the IPv6 gateway address from the router? (Just trying to work out how far the IPv6 connectivity, if any, is reaching)
HairyMcbiker
All Star
Fixes: 21
Not as such:
I get "Error : link local address requires a destination address"
But the tests on the "Check connectivity" show
Enabled/OKConnectivity to IPv6 Gateway (fe80::90:1a00:ca3:8d26)
w23
Fixes: 4
Not sure exactly what it means (or how, if at all, it helps) but fe80... is a local link address.
Call me 'w23'
MJN
Seasoned Pro
Fixes: 5
Quote from: Hairy
Not as such:
Always show your commands. As per the original post there is every chance they could be wrong and so only quoting the output could be misleading. In this cases chances are they're correct however these error messages are all new to us and so we don't yet fully understand the nuances of what they might be saying.
For the same reason I would also ignore the GUI-level tests as it is not fully clear what it is they are actually testing (and how).
HairyMcbiker
All Star
Fixes: 21
So that would suggest that it ISN'T getting an ipv6 address?
The user id is [email protected]
So it should be getting one.
I tried copying from the terminal but it wouldn't let me copy it.  fixed changed from xterm;
It isn't showing an ipv6 dns server:
TCP/IPv6 Settings
IPv6 State: Enabled
IPv6 Address: fe80::a6b1:e9ff:fe98:142e/64
IPv6 Default Gateway: fe80::90:1a00:ca3:8d26
Local Interface ID: ::a6b1:e9ff:fe98:142e
Remote Interface ID: ::90:1a00:ca3:8d26
DNS Server 1: -
        Pingv6 Timeout(.)
{Administrator}=>ping proto=ip addr=fe80::90:1a00:ca3:8d26
Error : link local address requires a destination interface.
{Administrator}=>
