V6 on the TG589 v3
- Trials
- IPv6 Trial
- Re: V6 on the TG589 v3
V6 on the TG589 v3
16-12-2013 11:07 AM
The menus are not allowing me to enable v6.
Quote TCP/IPv6 Settings
IPv6 State: Disabled
Stateless Address Autoconfiguration: Disabled
IPv6 Address: -
IPv6 Default Gateway: -
Local Interface ID: -
Remote Interface ID: -
DNS Server 1: -
I have tried telnet and set the ip config ipv6 to enabled. Rebooted but still no luck.
Any clues?
16-12-2013 11:12 AM
The 'IPv6 State: Disabled' line suggests however that the CLI config didn't work. What were the exact commands you entered? A reboot shouldn't be required - the ppp ifdetach/ifattach components should cycle the PPP connection with the new config anyway.
16-12-2013 11:16 AM
Just used jelv's instructions for the older one and it seems to have worked.
IPv6 State: Enabled
IPv6 Address: fe80::a6b1xxxx::xxxx:142e/64
IPv6 Default Gateway: fe80::90:xxxx:xxxxab17
16-12-2013 11:28 AM
Rebooted pc have both ipv4 & v6 ip's.
Router tests say:
Quote Test Results
Test Succeeded DSL
Test Succeeded Ethernet
Test Succeeded PPP
Test Succeeded Native IPv4
Test Succeeded Native IPv6
Test Succeeded Internet
Enabled/OKConnectivity to IPv4 Gateway (195.166.128.189)
Enabled/OKConnectivity to IPv6 Gateway (fe80::90:1a00:xxxx)
Enabled/OKConnectivity to DNS Server 1 (212.159.6.10)
Enabled/OKConnectivity to DNS Server 2 (212.159.6.9)
But the ip6 test pages show ipv4 ONLY.
16-12-2013 11:36 AM
Phil
16-12-2013 11:48 AM
In the router I have:
Quote TCP/IPv6 Configuration
IPv6 State: Enabled
Advertising prefix: --
Use Stateless DHCPv6 Server: Enabled
Should that autoconf be ENABLED?
16-12-2013 12:00 PM
I'm not at home at the moment to give a screenshot.
Your advertising prefix possibly seems similar to my "Interface Address / Prefix length" which I had to enter the correct value in to get it to work.
Phil
16-12-2013 12:11 PM
Only option on the web page is enable/disable stateless.
16-12-2013 12:19 PM
Quote from: Hairy But the ip6 test pages show ipv4 ONLY.
You need to provide a bit more clarity. For example, post the output of the results from test-ipv6.com.
For the most basic test, also try an IPv6 ping from the router:
ping proto=ip addr=2001:4860:4860::8888
16-12-2013 12:30 PM
When both protocols are available, your browser uses
IPv4
Your internet connection is not IPv6 capable
unable to contact IPv6 test server
router:
Quote {Administrator}=>ping proto=ip addr=2001:4860:4860::8888
Legend : Pingv6 successful(!)
Pingv6 Timeout(.)
Hit ctrl-g to abort...
--- Pingv6 statistics ---
5 packet(s) transmitted, 0 successful, 100% packet loss
16-12-2013 1:24 PM
Can you ping the IPv6 gateway address from the router? (Just trying to work out how far the IPv6 connectivity, if any, is reaching)
16-12-2013 1:39 PM
I get "Error : link local address requires a destination address"
But the tests on the "Check connectivity" show
Enabled/OKConnectivity to IPv6 Gateway (fe80::90:1a00:ca3:8d26)
16-12-2013 2:05 PM
16-12-2013 2:24 PM
Quote from: Hairy Not as such:
Always show your commands. As per the original post there is every chance they could be wrong and so only quoting the output could be misleading. In this cases chances are they're correct however these error messages are all new to us and so we don't yet fully understand the nuances of what they might be saying.
For the same reason I would also ignore the GUI-level tests as it is not fully clear what it is they are actually testing (and how).
16-12-2013 2:28 PM
The user id is ipv6test17@plusdsl.net
So it should be getting one.
I tried copying from the terminal but it wouldn't let me copy it. fixed changed from xterm;
It isn't showing an ipv6 dns server:
IPv6 State: Enabled
IPv6 Address: fe80::a6b1:e9ff:fe98:142e/64
IPv6 Default Gateway: fe80::90:1a00:ca3:8d26
Local Interface ID: ::a6b1:e9ff:fe98:142e
Remote Interface ID: ::90:1a00:ca3:8d26
DNS Server 1: -
Pingv6 Timeout(.)
{Administrator}=>ping proto=ip addr=fe80::90:1a00:ca3:8d26
Error : link local address requires a destination interface.
{Administrator}=>
